Thread: 2.0dti juicy
    Regular Member matt.d's Avatar
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    Engine : 1.8 16v petrol
    Default 2.0dti juicy
    cleaned my egr valve the other day and now the cars juicy as hell im not all that lead footed put 40 quid in it today and it took the needle over half way 16 miles later its well under half way why is this there is no smoke from exhaust or any other faults i hope
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Really you'd need to work out the actual MPG rather than relying on the needle alone. I've noticed the marks on my 2.2dti aren't even regards mileage ie full to next mark down is 100miles, next mark down from there is 50miles, then next mark is 50, then another 100 giving me 300 total by half way. Odd but I've gotten used to it.
    As above. The tank is not a box, or anywhere near it, so the needle doesn't move linearly throughout the range. Mine does 100 miles before it even starts moving, gets to about 400 by halfway, but only gets to about 650 ish by the end of the range. The speed it moves varies throughout.
    You need to brim the tank, drive till it's nearly empty, brim it again, and using the amount of fuel you put in the second time versus the mileage you've done you can work out the economy...
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    ok thanks for your advice my old vectra b was a pain in the arse with the needle being wrong anyway will follow your advice i let u know if i think its more juicy or not many thanks
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    This is quite interesting as i've just done completed a full inlet manifold clean, new EGR and silicone boost and vacuum pipes on my 2.2DTI.
    Even before the above I would get no more than 420 miles to a full tank and now I get 460 miles. 60% of my daily drive is motorway and the rest A roads. How can you be getting over 600 miles to a tank on a 2.2?
    Apr 2011
    Somerset
    Should have done a bit better research I think. CDTI's give a lot more on MPG than the old oil burners. My best average is 52Mpg but that is hard to get and tend to hover around 48Mpg which is still quite good for the old lady.
  1. Mpg 2.0dti
    By thestaffy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2012, 12:22
  2. vec c 2.0dti sxi
    By mgp in forum Introduce yourself.
    Last Post: 26th October 2009, 19:13
  3. 2.0dti egr..
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2008, 11:49
  4. 2,0dti CAT
    By dervdoc in forum Parts for sale
    Last Post: 2nd May 2007, 14:43
  5. 2.0dti
    By thestaffy in forum Diesel Engine related
    Last Post: 17th March 2007, 14:22
