Thread: Weird wiring?
    Regular Member GoldenWonder's Avatar
    Durham
    Default Weird wiring?
    I've just come back into the Vectra fold -now owning a 2006 1.8VVTi model and I wanted to put my JVC KD-R311 stereo into it.
    I bought the quadlock iso adaptor and put everything in - no power at all. After much faffing about I dug out an old quadlock connector (from a ford I believe) and used that to 'test' the wires. It seems that if I connect the red and yellow wires (stereo end) to the red wire (car end) the stereo works, but works completely independently of the ignition.
    Is that normal? When the stereo was in my previous car (a vw) the iso harness worked ok, but it still worked independently of the ignition.
    I wonder if its just an oddity with this stereo with canbus cars? My old Vec was a 2004 so it didn't have the canbus stereo which made it a lot easier!
    I would trying searching for an adaptor for the steering controls but this has put me off if the bog standard adaptor doesn't work!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yes it's normal in the Vec's there's no ignition feed to the radio in the later ones as it's controlled by the can-bus system.
    Run the ignition wire from the radio down to the back of the cigarette lighter and it will work as you'd expect
    Durham
    Cheers - I'll have a look at that!
    I guess the newer canbus cars just 'tell' the head units to switch themselves off?
    Durham
    Managed to hack into the 12v socket and it works with the ignition now - cheers for that!
  1. Weird cut out!
    By Chip in forum Engine & Drivetrain
    Last Post: 4th June 2012, 18:35
  2. Just Weird!
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2010, 14:11
  3. em..... am i weird...
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 11:35
  4. Weird???
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 21:15
  5. Weird MPG
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2006, 23:10
