Results 1 to 10 of 14
Thread: Boost problem Z20net
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default Boost problem Z20net
    Done the seraches on here for possible issues causing this.. found nothing i already know of
    Basically its like driving a car without a turbo at times!? Boost up to 5psi.. if im lucky sometimes 10psi.. when she was running good i get about 16psi
    No fault light has come up when the car is runing poo.. but seems to be running naff all the time now
    I have replaced both the small boost sensors about a year ago.. on top of the actuator and the one at the front of the engine... could these go belly up again? Are they man enough to be running with BSR stage 3 or will this not make any difference?
    Regular Member sberrow's Avatar
    Newport (Gwent)
    Im running a derivative of stage 3 bsr and i go through boost sensors like they were made from butter, every 4-6k miles. the further i get away from bsr map the better it gets. do make sure you get the sensors the right way round. ie the right part no. in the right place.
    Newport (Gwent)
    does it rest after you turn the egnition off and on??
    oh well.. I tried..
    I swapped the sensors one at a time to make sure i didnt mix em up.. i know what im like lol
    It is ok to start with on a new journey after ignition off, then plays up again after that
    Might go get a new pair of sensors then as its about that kind amilage i have covered.. thanks
    WGAF#5
    also the integrated recirc dump valve diaphragm/spring may be weakened or split ... there is a repair kit from VX which is about £100
    part no 55558271 this was the primary cause of mine when we initially though it was the recirc valves
    once replaced i didn't loose boost or drop into lhm during overtakes
    mine had hairline splits on the edges allowing air to escape at the most inopportune moments
    Regular Member mann3210's Avatar
    scotland, perth
    how do you know if your turbo is playing up? iv noticed some times my car is performing superb but some days it feels like its holding back ever so slightly still very sweet but just not as great as the better days lol
    oh well.. I tried..
    I can still hear 'dumping' from the engine.. would it still do this if what you said was split in anyway?
    WGAF#5
    Quote Originally Posted by blue estate View Post
    yep ... it would just be dumping the boost early before optimum pressure is reached
    oh well.. I tried..
    Ordered the two sensors again.. cheapest first as you say lol.. hope that sorts my little rocket out
    Regular Member Jezzy's Avatar
    S.E
    Dez, was your problem intermittent or did it happen every time?
  1. Z20NET - Boost pipe buy.
    By FIL 4822 in forum Petrol Engine related
    Last Post: 4th September 2011, 19:22
  2. z20net boost gaugw were to tap in for vacum?
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2011, 10:25
  3. hissing boost on 2.0t (Z20NET)
    By Caveman_nige in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 17:25
  4. z20net boost in psi??
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 16:48
z20net boost problem
z20net common problems site:www.vectra-c.com
