Thread: Air con noise?..
    Regular Member bigdave1701's Avatar
    York
    Default Air con noise?..
    Last summer my aircon worked fine. This spring its started making a hollow whoosing noise when switched on (sort of like an empty gas clyinder being filled) now nothing happens when switched on. Is it just that it needs a re-gas or is this likely to be new compressor time too?
    11 Post(s)
    Have you used it at between then and now?
    Sorry if it's teaching grandma to suck eggs, but AC needs to be run regularly to stop the rubber seals drying out and in turn to stop the refrigerant and PAG oil leaking out.
    AC is for all year use, not just hot days. It can also be used in conjunction with the heater (as per how climate control works) and makes for a great window demister.
    York
    It's been used intermittently throughout winter. Perhaps 30 mins a month in total?..
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Mine did this when I picked it up last week. Took it to Kwik-Fit for a re-charge (they give you your money back if they can't make it colder) and it was sorted! £49 and a cool interior!
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
