Thread: Dial Card Swap
    Regular Member coldo's Avatar
    Scotland
    Default Dial Card Swap
    Hey all,
    Need to borrow your genious again!
    The dial's i have in my LS as the simple black ones etc. I have spoted a set of clocks from a broken vectra SRI which are the same rates (speedo values and rev limit values etc).
    As my clocks have had the SMD conversion completed on them i do not simply wamnt to swap the clocks over. Instead i am looking to swap the dial cards and needles over.
    Has anyone done this so i know it is possible to do?
    I am assuming it is simply a case of taking the clocks apart (pastic casing off them etc), removing the needles and the dial cards and swapping them for the set in my car's current speedo....
    Any insite onthis would be appreciated before I make a bid for these clocks.
    Colin
    Regular Member PANDY 3.2 V6's Avatar
    sunderland
    Just one piece of wisdom from me, just make sure you mark the resting position of all the needles before you take them off, and put them back in exactly same place when putting back together, even 5mph out on the speedo could cost you done points on your license for accidentally speeding, and wrong clock is not a defence!
    Scotland
    Yeah... will be making doubly sure of this...!
    Won the clocks off ebay. Managed to get a set of Vectra SRI ones which match mine perfictly... So result there....
    Manage to find the guide for ripping them apart...
    I can see a whole guide / walk through happening for when i do these...
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I diid exactly this with my old SXi saloon, bought an SRi dash off Ebay and used the front of that and transferred it onto the back of my original dash. No problems at all, hardest bit was lining the needles up again correctly afterwards.
    Scotland
    Quote Originally Posted by Ian-Highlander View Post
    Well, got the new dials through yesterday so I dismantaled the cold clocks, swapped the dial cards and needles across and then fitted them all back in....
    All seems to be ok... Will get pictures posted up soon.
    Just a quick question on resetting the needles. When I fitted them i located them above the stop position and then moved them down (they clicked as they moved) until they were what i assume as correctly seated. I started tyhe car and they all are sitting where they were before hand (fuel, temp, rev counter etc). Is this the right process for fitting them or is there anything else i need to do to calobrate them?
    Col
    Scotland
    Some before and after pictures for you of the dial card swaps...
    Im sure you will all agree that the new dial cards look much'os better'os...
    OLD (not my picture but these are the exact same clocks)
    NEW
  1. dial smd type
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 20:32
  2. fan speed dial
    By larann in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 21:54
  3. All Dial Failure!
    By j13hdb in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2010, 16:08
vectra c speedo cards
