Thread: Best way to build up 314/345 calipers
    Regular Member R2XPT's Avatar
    Scotland
    Default Best way to build up 314/345 calipers
    The spring thing at the front, how to put that back on without scratching all the new paint off the caliper??
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    very very difficult to do, i tried masking tape where spring slides but to no avail, touch up afterwards and they look great
    Midlands Mod Shop - NFFC.
    Oct 2006
    southampton
    15 Post(s)
    Find your nearest rubber supplier and get a piece of 1mm thick neoprene rubber and place on the caliper where it catches, grease it or washing liquid to enable it to slide on the rubber, ill send you a bit if you cant get any HTH
    Scotland
    Ok thanks for the help guys, I got 1mm smooth flat glass packers, they should be ok to use u think?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    2 person method, hook in one side in place and get them to hold it there whilst you spring the other end of the clip in.
    WGAF#5
    Quote Originally Posted by plasma View Post
    yep worked well as we found out on Sunday when Dean replaced his ....
    one side has a few small marks (single person) the other is mark free (two persons).
    Sodding Typical on Sea
    Ray, this one has always been the bain for me too, I have always had to touch up the damage after construction.
    I did once hear of someone who attached the clips before fitting to the car and was able on the bench to install with no damage,but have never actually done this myself.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    2 sets of long nose vice grips?
    Scotland
    Sorted it tonite, bruit force, done them without anything bar my hands, little chip but fitted in fine, just need to get time to fit them now!
  1. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  2. Oil build up questions.
    By Mogsy007 in forum Diesel Engine related
    Last Post: 28th February 2010, 10:44
  3. Buy Vs build a PC?
    By wardy in forum General Chat
    Last Post: 13th September 2008, 19:38
  4. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
  5. My boot build
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 07:51
