Thread: signum turbo problems
    Jun 2011
    fife
    Default signum turbo problems
    Hi folks, got a stange one for you.
    I have a signum 2.0 turbo z20net. which i bought with a dead engine. So i purchased a new engine with less than 20k on it, and proceeded to fit the new engine in to the car, repacing only the engine and using all of the original cars electrical components and mechanical bolt on parts.
    Once it was all fitted and put back together we then went for first start and the starter just keeps engaging and turning the engine over ?.
    So we removed the solenoid wire from the starter and turned on the ignition and fed the solenoid post power and the engine started first time and runs sweet as a nut.
    So the car runs excellently with the solenoid wire off.
    So we plugged in the modis and it throws up some weird codes ?
    It says low voltage to boost control valve and low voltage to somewhere else, cannot remember where.
    so as it was running ok i took it out for a shake down test and the turbo does not do anything. The actuator and the turbo are brand new. But no boost.
    Please help. I just hope someone else has had weird problems like mine.
    Thanks for reading.
    Any help is most welcome and thank you in advance.
    regards
    Sandy.
    WGAF#5
    the actuator and turbo may be new but are they adjusted ?
    if not then they will throw up codes..
    i would look at your old actuator arm and unscrew it counting the revolotions until its removed ... then remove the new actuator arm and rethread and count the revolutions to ensure there the same/ as close as possible ..
    also as im summising that yours was a preface 2.0T was the new engine out of a similar aged vehicle?
    is the new turbo the same as the old one ?>
    i.e. old was garrett... is the new one a garrett or a mitsubishi ? if so then the engine data on your car would not be correct as the mitsibishi can be a more powerful unit hence why its fitted to the face lifts ... if this is the case then you need a live map to correct the issue BUT widing the actuator arm out and making it longer would help to reduce the car boosting too early BUT could eend up causing further damage
    Jun 2011
    fife
    cheers for the speedy reply deztroyer.
    the turbo and actuator was the ones on the other engine that threw the chain, it was replaced by vauxhall in may. and the car ran sweet as a nut. The new engine that went in to the motor was an identical plant to what came out just alot lower mileage. But i personally hope that the rlectrical problem is just throwing the car in to limp mode.
    Cheers sandy.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You already have a thread about this running, thread closed so it's not split across 2 threads
    Irmscher Insignia CDTI 130
  1. signum turbo problems
    By sandy white in forum Engine & Drivetrain
    Last Post: 2nd July 2011, 19:54
  2. Turbo problems?
    By warren77 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:04
  3. Turbo problems on my signum 2.0dti
    By cookieboy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 12:54
  4. Turbo problems?
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2006, 15:12
signum 2.0t turbo problem
