Results 1 to 2 of 2
Thread: 2.2DTI engine cuts out except when airflow unplugged
    Jun 2011
    nottingham
    Unhappy 2.2DTI engine cuts out except when airflow unplugged
    Update on my 2.2DTI Vectra- keeps cutting out when driving and hunts / won't restart easily. New EGR, same problem continued. Diagnostics inconclusive (shows glow plug problem?)
    Unplugged airflow meter- car has done 1000 miles without a peep but only 2000rpm. Got new airflow meter- plugged it in, problem returns! Plugged it out, car runs ok (smooth but not beyond 2000rpm ie no poke)
    Flummoxed.
    The wire to the airlfow sensor plug is Y shaped, one end being the airflow sensor plug. The other end of the Y has a lug on it attached to a metal bracket that looks like it should be bolted down somewhere or plugged in to somewhere but there's no obvious place for it to live. May be a red herring as this has seemingly never been attached to anything even when the car was running normally.
    Ideas?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be you've replaced it with a faulty MAF or from your description, you have found a possible sensor cable issue. I don't know tbh m8, I don't know much about the DTi. Stick up a pic of the cable/plug in question and bump this thread as there are plenty of DTi owners on here.
  1. unplugged maf - engine light on
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 19:03
  2. 2.2DTI engine cuts out
    By ruthstatham in forum Engine & Drivetrain
    Last Post: 18th June 2011, 22:55
  3. Replies: 13
    Last Post: 7th April 2011, 15:39
  4. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  5. 2.2DTI - Revs drop and engine cuts out
    By altheman2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2008, 20:55
