Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Signum 2.8V6T idle speed high
  1. #11
    Glasgow
    Yeah i think its all about the turbo etc getting a good oil feed when it starts just before the revs drop i get a very quiet noise from around my turbo sounds a bit like the air noise when you open a can of coke, as soon as that happens the revs drop. I always leave it till the revs drop when i start it before i drive off dont want to put anything under stress while its doing its thing.
  2. #12
    Glasgow
    Quote Originally Posted by BYGino View Post
    Ahh, that makes sense I guess. I really should just wait the 30secs or so before hammering the gas then!
    If you start up and go or give it the beans before the engine heats up you will end up needing a new turbo lol.
  3. #13
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Ahhh yes you reminded me of that pressure release noise you get when the revs drop... definately a turbo related reason.
    And you shouldn't be giving it beans even after 30 seconds fella!!! :P Wait for the coolant temp to atleast read around 75-80 before even thinking about it as by that time your oil should be running up to temp... Otherwise your asking for some long term damage.
    Also after a good rag, remember to drive with low revs like an old lady for the last 30 secs to a minute of your drive to let everything cool down and the turbo to slow down. The other option is to pull over and leave it running on idle for around the same time but as seen in the handbook you don't get as efficient oil cooling that way
  4. #14
    Glasgow
    Quote Originally Posted by luke4487 View Post
    Spot on mate, thats pretty much summed up how to look after your investment
  5. #15
    Bordon, Hampshire
    Haha yeh still paranoid the turbo is gonna go or something. She runs sooooo rough when cold in the winter and not exactly brilliant for the first minute or two after leaving it over night in the summer. You got the standard VXR exhaust or an aftermarket one fitted? My next investment
  6. #16
    Glasgow
    Just running the standard system mate as its a remus there not much point changing it unless your wanting a different sound. I find the standard one sounds the dogs danglys lol. If i was wanting it louder i would get the cat off it but its already very deep if you stand behind it even just on idle.
  7. #17
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Yes normal mine too. The engine stays high rpm and a pump helps to heat the cats up quickly for emission reasons no fault
  8. #18
    Bordon, Hampshire
    A mate has the estate and I found the exhaust a bit tame. Although the pop pop pop after letting off the throttle is awesome. I think I will go for something a tad louder, and probably lose a cat so its a bit deeper when flooring it! Can't wait lol, the Signums are soooooo tame
  9. #19
    Glasgow
    Lol yeah a nice exhaust would make a huge difference to yours would really bring out a good sound.
  10. #20
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Guys, guys! I was only joking about hammering it - I always drive like an old lady
    Seriously though, I usually do let the oil warm up etc. When I left for work this morning I took note of how long it stayed at 1400 revs. After about 30 secs or so it dropped to about 1000 so it looks like everything's normal.
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. battery charging rates at idle and high speed
    By justin32 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 01:29
  3. Very high idle speed (3500rpm)
    By CodeV in forum Engine & Drivetrain
    Last Post: 19th February 2010, 01:08
  4. 1.9cdti - high idle speed and new "noise"
    By mossie in forum Engine & Drivetrain
    Last Post: 7th October 2008, 16:12
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
https:www.vectra-c.comforumshowthread.php141004-Signum-2-8V6T-idle-speed-high
