Results 1 to 10 of 20
Thread: Signum 2.8V6T idle speed high
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Default Signum 2.8V6T idle speed high
    Hi all,
    I've had my new Signum for a couple of weeks now and have just noticed something that doesn't seem right. I haven't spent any time diagnosing the problem yet but I thought since everyone over here is so knowladgable and helpful, I thought would ask here just in case anyone has seen this before. The car is overdue a service and I'm just waiting on the parts to arrive so the service may actually cure the problem but I really think it's something else.
    When I first start the car it idles pretty high (somehwere between 1200-1500 RPM) and seems to stay like this for ages (haven't really left it for any great length of time though to see if it will go away.) The minute I move from park into drive or reverse it drops down to about 800 RPM or so and if I move it back to park again it doesn't go back up and idles away quite happily round about where it should be.
    Has anyone else seen this on a 2.8 Auto?
    Regular Member PORKBALLS29's Avatar
    Epping
    Its the same on all the 2.8s mate so nothing to worry about. Mine, Dez's and Ian(Soulman) all do this.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    As H said they all do it! worried me also
    WGAF#5
    yaaarp .... prefectly normal
    holds for upto a minute then drops to about 1000rpm until you pull away
    It's because they're petrols so have naff-all torque and risk stalling at low RPM's when they're cold...
    Jun 2011
    Phew, was a wee bit worried there, thought I was in for diagnostics fun!
    Thanks guys.
    New Member Tmd's Avatar
    May 2011
    UK
    I find when cold mine revs to 1200 Or 1400 or so, I sit and wait 30secs then it drops to idle at about 800 rpm then I select D and drive off. If you try to select D or R when revs are high it clunks a little so I prefer to wait till revs drop. Try it I think it's kinder on the box.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by Penfold101 View Post
    hmmmmmmm 350ftlb you want more ??? lol
    and yes mine does the same ....but sounds sweet with my exhausts
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    The Ford Focus ST's do it also... I think its less of a torque problem (as for 100 years petrols managed without the high rev startup) and more to do with the turbo...
    The handbook advises against letting the engine warm up on idle... some say this causes more damage as the oil can't get to all of the right places with such slow speed of movement... therefore, slightly higher revs would produce a lot more oil splash and coat all the right places quicker, while still being low enough not to cause any unnecessary wear to internals.
    Thats my theory anyways... and because of that I always let it drop before driving off
    Jun 2011
    Ahh, that makes sense I guess. I really should just wait the 30secs or so before hammering the gas then!
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. battery charging rates at idle and high speed
    By justin32 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 01:29
  3. Very high idle speed (3500rpm)
    By CodeV in forum Engine & Drivetrain
    Last Post: 19th February 2010, 01:08
  4. 1.9cdti - high idle speed and new "noise"
    By mossie in forum Engine & Drivetrain
    Last Post: 7th October 2008, 16:12
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
https:www.vectra-c.comforumshowthread.php141004-Signum-2-8V6T-idle-speed-high
