Thread: My current list of faults...
    Regular Member bigdave1701's Avatar
    York
    Default My current list of faults...
    Anyone offer any possible causes for any of these (2.2dti sri):
    • Banging from the back end (not upper control arms).
    A solid knocking/banging when going over uneven road surfaces but is not caused by one particular wheel going over a bump.
    • Metallic grind when pulling away.
    Doesn't happen all the time, just when the engines cold and only for the first 2-3 times you pull away.
    • Slight whine/grind when pulling away in or near full lock.
    • Front suspension creaking
    Only really notice it when going on or off the driveway. Slight creak and clunk
    Quote Originally Posted by bigdave1701 View Post
    Anyone offer any possible causes for any of these:
    shock absorber worn or coil spring broken
    check brake disc back plate isnt bent or touching disc or have a stone stuck in it
    arb bushes / suspension top bearing / drop links / spring mod not fitted or slipped out of place
    Jun 2011
    Suffolk
    The banging going over a speed bump could be the spring rising out of the damper then dropping back down. Do you have after market springs on standard dampers?
    Other things could be wheel bearings.
    Quote Originally Posted by Innocence View Post
    the springs on the rear dont sit on the damper they sit on the lower wishbone
    York
    Cheers,
    The suspension is all standard SRI lowered suspension.
    Would I be able to tell just by looking at the shock if its knackered? And is it one of those really annoying parts that needs to be changed in pairs?
    Jun 2011
    South Yorkshire
    Hi I recently purchased a 2007 estsate SRI 1.9CDTI 150hp and because of various noises from the front and rear I have ended up changing all four springs as three we broken. The front suspension leg shocks, swivel joints, Top mounts and drop links on the front. Much better now. The knock from the rear was a broken spring on the OSR and I actually heard the NSR go when I was driving. The bit of broken spring was banging on the bottom mount. The front broken spring was not noticable as it had broken inside the lower plastic sleeve so it was not obvious on the visual inspection. Apparently these issues are well known.
    Full Member spennny's Avatar
    Blantyre
    I have the same issue mate and only started happening when i lowered the car, i think the culprit on mine is here
    http://www.vectra-c.com/forum/showthread.php?t=136737
    I haven't changed it yet as apparently there is a "opel vauxhall bush removing kit" which i cant seem to locate and makes the job 20 mins per side
    EDIT: This is the kit but i dont fancy forking out £50 for something i may use only once
    http://www.vehicletools.co.uk/sealey...sh-7597-106908
    York
    I've been under there poking around and think you may have found the source of my banging! That kit is for the vectra B so I wouldn't know if it would be any use anyway?.
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Could be top strut bearings. Sorted mine this way. Easy enough to do.
  1. List of current issues!
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 21:26
  2. My current set up...
    By danBoy in forum ICE Gallery
    Last Post: 4th July 2009, 12:26
  3. my current vectra
    By steven77 in forum Non Vectra C/Signum Album
    Last Post: 6th March 2009, 02:09
  4. My car in its current state...
    By danBoy in forum Quick Photo Album
    Last Post: 27th August 2007, 21:20
