Results 1 to 10 of 21
Thread: Geometry Settings after Lowering
    N
    Default Geometry Settings after Lowering
    Hi,
    Fitted a set of PI -30mm lowering springs and need to get the car aligned in the next few weeks. I called up a local place with the hunter equipment, but when I stated it was lowered, they said they could only use the manufacturers recommended spec. Since its been lowered, I presume these settings are no longer valid? If not could someone please let me know what they should be, so I can give them to the garage directly?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I want with OPC/vxr settings, but will be interested to see the response
    Engine : 1.9 CDTi
    Mine was set to the 'Sports' settings.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Going to bump this incase anyone else has an opinion
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by lee gsi View Post
    Sports will be sri, so only 15mm lower not 30mm
    Also if running spacers should this effect the settings used?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Yet again, Hunter's website does NOT endorse garages or the muppets using their equipment, they simply state where their gear is installed.
    If you want someone who knows about geometry, find your nearest garage here http://www.blackboots.co.uk/tyre-fitting-centres.php.
    Also have a read up on the techy stuff before you take the car in to anywhere so you don't get fobbed off with bull****.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by gtr1000 View Post
    Surely though in the same way there are settings for a standard vec etc Eibach should have released settings for there setup?
    West
    I'm sure i have seen some sports geo settings posted on this forum some time ago
    West
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cheers mate
  1. 4 wheel geometry / alignment
    By stevie16v in forum West Scotland
    Last Post: 20th October 2012, 03:52
  2. Signum Geometry
    By pscocoa in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 13:57
  3. Geometry Check
    By Exclusive BV in forum Handling & Braking
    Last Post: 30th May 2010, 16:23
  4. lowering puts settings out?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 18th August 2009, 16:59
  5. Vehicle Geometry @ WIM
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2008, 20:06
