Thread: Y30DT - Turbo Cover - easiest way to block EGR valve
    New Member pembuk's Avatar
    Jun 2011
    Poland
    Question Y30DT - Turbo Cover - easiest way to block EGR valve
    Hi all 3.0 cdti owners
    It's my first post on this forum, so "Hi" for everyone
    I'll try to block EGR valve before he's not broken yet. I found the best place to this between turbo ( exactly exhaust manifold) and gas cooler (this one before the EGR valve). But i can not remove turbo cover. I unscrewed 4 bolts ( two on top, one on right side and one at the back. But the cover still does not want to go. Is there more bolts there? Or mayby is some easiest way to block EGR valve in Y30DT?
    Thanks you in advance for your replay.
    Sorry for my English. I'm still learning
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I remember my mechanic had trouble removing the heat shield too. I think there's a 5th bolt on the left, but I've a short memory lol
    Jun 2011
    Poland
    Is your EGR also blocked?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    No...I replaced the turbo on my old Y30DT. I blocked the EGR (partially) on the inlet part for a bit...removed the blanking plate after a while.
    Jun 2011
    Poland
    What was the reason of removing the blanking plate? Some problems with errors in ECU or something else? I heard, that when you blank EGR the ECU will give you an error. But I don't really know, how ECU can knows that EGR blocked is? Only then EGR is broken and signal about his position incorrect is (I think so). So when EGR is ok, and you blank him before, ECU shouldn't knows that. That's why I want to try blank EGR before gas cooler.
  1. Easiest way to remove turbo heat shield?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 29th October 2012, 20:01
  2. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  3. how 2 on cleaning egr valve 3.0 v6 cgti y30dt
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 19:32
  4. Y30DT EGR Valve
    By r.bailey63 in forum Engine & Drivetrain
    Last Post: 2nd August 2009, 23:35
  5. Valve cover gasket
    By F4LSE in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 15:15
vauxhall vectra 3.0 v6 cdti egr valve
vectra 3.0 cdti egr valve removal
https:www.vectra-c.comforumshowthread.php140981-Y30DT-Turbo-Cover-easiest-way-to-block-EGR-valve
y30dt remove rear exhaust manifold
