Results 1 to 10 of 13
Thread: Boost encrease
    Jun 2011
    London
    Default Boost encrease
    My boost guage shows me 1.4bar @3000rpm,second gear.decat,intercooler pipes,breather,vacoom hoses done.can anywone tell me if i can encrease the boost mechanically(without a remap)and should i?benefits and danger!?
    Jul 2010
    Yorkshire
    Diesels make power from fuel, not air like on petrol cars. raising the boost may only cause you issues.
    Get a remap.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Diesel make power by heating air to creat pressure and work a piston. Thus more air will give more pressure to work the piston and more power unless the temperature of the higher pressure air is signifficantly higher. You can increase the boost manually but it's not as simple as fitting a bleed valve because it has vacuum controlled variable angle nozzles, controlled via a solenoid valve by the ECU. Also you would experiance high boost spikes in all likely hood.
    If you have a remap to raise the boost, it is best to do so only at the lower end (below 3500-4000)to prevent over-speeding the turbo
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    You can do something to the actuator on the turbo wastegate so it doesn't open quite as soon which will raise the pressure a little but do it too much you'll either blow off a pipe or put it into limp mode because the boost sensor will see too much pressure.
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Actually, I don't think the 2.0DTI is a VNT. The 2.2DTI is listed as a GT1849V but I think the 2.0DTI is a GT1544S, which, has an internal waste gate. In that case, it may be pressure controlled rather than vacuum and a bleed valve could be effective. Take off the pipe line to the actuator and see if there is pressure in the line.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by nutron View Post
    Correct, out of the DTi's only the 2.2 has variable vanes.
    Jun 2011
    London
    Thank u guys. I will check if it is presure o vacuum as soon as i get home then we take it from thereif u dont mind
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    just checked mine today (2.0dti) and it's vacuum controlled
    i mean,there's vacuum in that tiny pipe line to the actuator
    Jun 2011
    London
    so what do we do next?
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A bleed valve is no good then but you might be able to adjust the waste gate actuator.
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vectra dti adjusting wastegate site:www.vectra-c.com
