Thread: Misty Angel Eyes
    Regular Member jake.clay's Avatar
    Mar 2011
    York
    Angry Misty Angel Eyes
    Hi all. Just recently fitted my brand new angel eyes.... All was good until last night I realised one of them is full of condensation
    Has this happened to anyone else?
    What causes it and how can I de mist them???
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yip mine does it a bit. I just put up with it tbh.
    Regular Member farley2708's Avatar
    antrim n.ireland
    my passenger 1 misted up a couple of week ago,took it out,put it in front of a blow heated for a couple of hours,got it all nice dried/hot,refitted it but put a couple of sachets of 'Silica' gel in it aswell,that way they will attract moisture if it does it again.so far its looking good
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    My passenger one does the same, even in this weather it still has a nice mist in it. I like the desicants idea, I will try that.
    Mar 2011
    York
    Quote Originally Posted by farley2708 View Post
    That sounds like a plan!! Where do you put the sachets? Behind the bulbs?
    antrim n.ireland
    i used double sided tape & stuck it to the inside of the rubber cover,done the same on the back of the plastic cover for the main beam
    nothing worse than seeing it moving around in the headlight!!
    as for it being a pain.it only took 15mins to take it out,the same for refitting,looks a WHOLE lot better than the misted up look
    Mar 2011
    York
    I will try it when i get home. Thanks for the advice
    Feb 2011
    Selby
    I dried my (pre-facelift) headlight out by first waiting for a hot, dry day. Then taking out all the bulbs and pointing a 500W halogen work light at it, about 6" away, for an hour or so. You could see the misting gradually disappearing.
    Once it's dry, refit the bulbs and most importantly the covers on the back. If you're missing a cover, then moisture will just get in again. The headlights are effectively sealed once the covers are in place, so no more moisture can get in. Similarly - moisture can't get out either!
  1. Angel Eyes
    By Ziggy in forum Styling
    Last Post: 18th February 2009, 03:13
  2. fk angel eyes
    By mikk3 in forum Styling
    Last Post: 16th February 2009, 10:33
  3. HID and Angel Eyes
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 21:32
  4. thanx 4 the help with the angel eyes
    By stubopvectra in forum Styling
    Last Post: 22nd February 2008, 19:04
  5. Angel Eyes...
    By Dwabo in forum Styling
    Last Post: 29th January 2008, 00:57
