Results 1 to 10 of 13
Thread: Alloys stuck on hubs.
    Regular Member stickshift's Avatar
    North London
    Default Alloys stuck on hubs.
    I've got the usual problem of my alloy wheels being ceased on the hubs. I was going to use a less extreme method of getting them off without hammering them to scrap. Iíve tried the method of loosening the bolts and putting the handbrake on and dragging the back wheels along the tarmac but they are stuck fast. all I can think of doing is use a gear puller on them, I would put some wood behind the spokes and hook on to that and a socket on the centre hub and pull the wheel off, the only problem I've got so far is I can't get the centre cap off without damaging it. So I was wondering if anyone knows how to get the caps off when the wheels are still on the car?
    Or, should I take it to Kwikfit and hope they don't c@ck it up!
    Regular Member Harry's Avatar
    Uxbridge, London
    kick the **** out of 'em, that's all kwik fit would do anyway
    North London
    I'm about as good as an England goal keeper at kicking anything. The last time kicked in anger I ended up on my ****. lol
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    get some wood behind the wheel at the bottom and clobber that with the biggest hammer you can find (leave a couple of wheel studs on just loose to stop the wheel falling off) may have to turn the wheel a few times but it will come off
    The Blackburn End
    Time to get "The Big Hammer" out and indulge...............
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Quote Originally Posted by Harry
    Last time I changed the back tyres Kwik Fit did indeed have to do the above. The guy doing the job had to give up and the BIG kwik fit chap was called in to apply grunt and strategic banging with soft (plastic/wood) hammer
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just loosen the bolts, then rock the sh!t out of the back end (side to side). Worked on my old pug. Make sure you apply copper grease all over the contact area when replacing.
    Regular Member danlat1415's Avatar
    Lancashire
    Hi,
    One of my rear wheels stuck on the hub a couple of months ago and tried everything. Eventually took to Kwik Fit where they jacked it up and hit the wheel from the inside underneath the car with a big rubber ended mallet, which took a good few minutes of bashing, but eventually came free, then applied lots of copper grease before putting it back on.
    So I recommend Kwit Fit if you don't have the tools to do it.
    They did it for free, so no harm in trying.
    It happened to me, I was in Green Flag so I phoned them and they came round and battered the **** out of them with a piece of wood and a hammer, took him nearly 1/2 hour per wheel, said it was the worst he had seen ...
    North London
    Quote Originally Posted by rushy
    Rushy
    Did what you said, and it worked a treat, two seconds of wobbling and the wheel started knocking.
    Cheers.
  1. used front wheel hubs
    By paul.sessions in forum Parts for sale
    Last Post: 13th March 2011, 21:46
  2. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  3. Anyone have knowledge of VX driveshafts and hubs???
    By mucklestone in forum General Chat
    Last Post: 4th June 2010, 13:58
  4. vectra c abs hubs test
    By dieseldod in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2009, 23:33
  5. Wheels seized to hubs
    By MattW in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2008, 09:07
