Thread: wyning pulleys
    New Member djdee's Avatar
    Mar 2011
    holyhead
    Angry wyning pulleys
    there is wyning sound now coming from the engine? pulley,but which one is it?there are a few of them on the fleet,an mine has just started to do it?only wen i'm slowing down in gear,it sounds like a dynamo,an i've just put a brand new alternator on,could it be the automatic pretentioner on the aux belt???????
    West
    the idler pully wheel is whining on mine & has been for some time, it will be getting replace in the next week
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If it starts to whine, get it changed. I could hear a whine from mine when under load and couldn't put my finger on what it was, few weeks later the bolt snapped in the block for the tensioner and had to be drilled out. Not so bad if I was at home but being 80 odd miles away at the M6 Toll services didn't help!
    Feb 2011
    omagh
    Vehicle : vectra c
    Trim : life
    Engine : 1.9 cdti 120
    Mileage : 118000
    i had a whinning noise on my 1.9cdti, fitted idler pully. no differance. fitted new crank pully (£110 from vx and aux belt £18 from vx) and noise gone . told that rubbes bit of pully wears and causes belt to run out of alighnment
  1. Drive belt, pulleys and tensioner replacement
    By no1vic in forum Engine & Drivetrain
    Last Post: 13th November 2016, 20:41
  2. 120 and 150 fuel pump pulleys the same?
    By lee gsi in forum Engine & Drivetrain
    Last Post: 13th November 2010, 17:38
  3. access to pulleys?
    By neill in forum Engine & Drivetrain
    Last Post: 5th September 2010, 18:29
  4. Damper pulleys
    By the-wizard in forum Engine & Drivetrain
    Last Post: 1st August 2010, 09:56
  5. New pulleys?
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 09:49
