Thread: intercooler waste of money
    Regular Member jay6392's Avatar
    wiltshire
    Vehicle : vauxhall
    Trim : vectra c sri xp
    Engine : 1.9 cdti
    Default intercooler waste of money
    hi all
    i have been trying to find out as much info on this but nothing that i was after so can some one help me with the answer is it waste of money on a intercooler kit our is it worth very bit of money
    many thanks
    West
    If you're still running a standard turbo then don't bother, the current intercooler is more than adequate
    wiltshire
    Vehicle : vauxhall
    Engine : 1.9 cdti
    yes will be running the normal turbo only thing engine wise i am doing is airbox mod piper cross panel filter and regal eds remap
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Intercoolers are all the same. They're what they fit on the VXR's so should be good for just about owt!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A stage one EDS remap will not increase boost much if any, so an intercooler change is not needed. As soon as you start to tune up the 1.9CDTI, gains can be seen from a big front mounted intercooler. If you go too big, you could damage the turbo though. You get a pressure drop across an intercooler, more if it is bigger, meaning more effort is needed by the turbo to maintain the required boost level.
    So if you are sticking with the standard turbo and a remap/box, I would say put on a small front mounted intercooler, removing the standard intercooler and moving the heat exchanger back.
    If you are going down the hybrid route, go for a bigger intercooler. My front mounted intercooler is much bigger than standard and has completely changed the shape of the power graph for the better.
    wiltshire
    Vehicle : vauxhall
    Engine : 1.9 cdti
    Quote Originally Posted by nutron View Post
    no i am not going down the hybrid turbo route and was looking at the tx autosports intercooler if i need one or note with the regal remap which ever stage it will take me to
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The quoted Regal EDS remap will be stage one unless you ask for something different and the stage two on a standard turbo will be smokey. Stage three will destroy your standard turbo, so stage one is where I would be aiming for, with the TX or simular front mounted intercooler. You will need to remove the original intercooler to prevent the engine running hotter.
    wiltshire
    Vehicle : vauxhall
    Engine : 1.9 cdti
    oh right will doing things like that is not my area but guess some one will be able to do it so intercooler is a yes then i guess
  1. pointless waste of money....but its cool:-)
    By *enery* in forum Styling
    Last Post: 9th September 2012, 20:25
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. your own money or company money
    By dannysport18 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2009, 08:52
  4. Lost money? Then make some money!!
    By Taffyopel in forum Comedy & Humour
    Last Post: 26th September 2008, 13:49
  5. A waste of £40 or not???
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2006, 00:27
Why is vectra c intercooler big
