Results 1 to 3 of 3
Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi with refrence to last thread the code was p0400 f8 which is egr valve faulty but itook the secondhand one off and put my old one back on b cuz bloke who i bought secondhand one off said it was working ok but send it back for him to test, but i connected it to wiring and started car and it is opening and closing is this how it shoulkd work does any body know thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    have you checked for heavy carbon in the innlet manifold,if it's bad you will get the same code,remove manifold and clean if it's carboned up.
    Jan 2010
    norfolk
    hi jonny bravo ive cleaned all the inlet manifold so it was spotless and the flaps are working do you think it could be airflow meter or boost pressure sensor
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
