Results 1 to 10 of 19
Thread: 2.0t edition 100 lumpy idle
    May 2011
    bispham, blackpool
    Default 2.0t edition 100 lumpy idle
    yesterday whilst i was changing plugs on my gsi we thought we would have a look at brother inlaws lumpy idle on his 2.0t
    its completly standard no mods but on tickover it sounds like it misses only way he can make it run abit better is to have aircon on all the time but its still misses a bit
    had it on computer no faults reset ecu still the same so he tried new plugs still nothing so we went to halfords and bought a compression tester
    results came back
    no1 cylinder 9 bar
    no 2 cylinder 11 bar
    no 3 cylinder 11 bar
    no 4 cylinder 9 bar
    checked in book and compression should be 9.5 bar
    anybody else had this sort of problem is it going to be a head off job and send it away
    any info what he could try would be a great help thanks
    May 2011
    bispham, blackpool
    forgot to say the only mod that looks like has been done before he got it is it looks like its had a decat pipe fitted as where the cat under the should be is a nice shinney pipe so only boxes on the car is the precat pipe at manifold and the 2 boxes right at the back as soon as you take the revs up to about 900 the cars fine and doesnt seem to be loosing power as it feels very fast
    Regular Member Jezzy's Avatar
    S.E
    Haynes quotes 12.4 BAR for each cylinder. Did you remove all 4 spark plugs at once, or just the plug for each cylinder you tested at that moment?
    May 2011
    bispham, blackpool
    no removed all 4 at once the engine code for the car is z20net in the book it said 9.5 bar
    did we do it wrong should of we removed one plug test then refit and go to the next
    S.E
    No, it sounds like the right method - take all plugs out at once, otherwise you create pressure that slows the crank down I guess.
    May 2011
    bispham, blackpool
    i found a old post and it says it should be 9.5 like the vx handbook says
    http://www.vectra-c.com/forum/archiv.../t-118476.html
    May 2011
    bispham, blackpool
    anyone any ideas
    S.E
    No mate, that's the compression ratio, not the pressure reading.
    Worksop
    Any luck Mines like this too
    May 2011
    bispham, blackpool
    no no look up to now its looking like hes going to send the head to be sorted next mth
  1. sri cdti 150 lumpy idle/ low mpg?
    By stevesri in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 20:39
  2. 3.2 lumpy idle update
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 9th August 2011, 14:59
  3. Lumpy idle on 2.2 Direct SRi
    By Palmo in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 18:53
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
