Results 1 to 10 of 14
Thread: What fault code reader?
    Aug 2009
    Ascot
    Default What fault code reader?
    As per title which fault code reader should I get
    Nick
    Jun 2011
    Elland
    I bought (wasted money on) one from Ebay that would only read 'check engine' codes - ones from the engine ECU. Mine was an ELM 327 interface: avoid. This wouldn't read the 'spanner light' codes, as there are many ECUs on the car. Impressed with the OPCOM one I got later, as it would read all the fault codes, lets you export live data (you can then plot this in Excel, or similar). Quite a lot of functions for diagnostic tests (EGR function, throttle body function, forced \DPF regeneration - 1.9 diesels) etc. Talked straight to my facelift v6 CDTi, but couldn't get it to talk to some older VXs. That may have been me not setting it up right, though!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    I Got The U480 Code Reader From Fleabay...Does The Trick For Me
    May 2011
    bispham, blackpool
    i bought one the other day op-com for 25.50 from ebay connects to the laptop and its great just be careful we wiped ecu we had a fair few drinks and thought we would have a play took about half hour to work out what we done and sort it out as it cleared the imobliser code so we had to put it back in
    before we did that we cleared present fault code and cleared hidden ones little things like when a fuse went in the light it stored the code so took it off
    i will do it sober next time
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I´ve just bought this yesterday so haven´t had time to test as it has to be send to me in Denmark.. But from what the guys here in Denmark says this is the one to get...
    http://cgi.ebay.co.uk/OPCOM-CAN-OBD2...item19c6957d2a
    May 2011
    bispham, blackpool
    Quote Originally Posted by Hummelshøj View Post
    thats the same one i bought off the same seller only comes in english works with windows 7 and vista not checked xp works perfect
    north east
    Autel MS509 only found one car well van it wouldnt work on that was a diatshu hi jet, have used it on my vec, the mrs` Corsa, Renaults and Daewoo`s
    Regular Member recoveryman's Avatar
    glasgow
    Vehicle : vectra
    Trim : elite
    Engine : 1.8 petrol
    Mileage : 92000
    Jan 2010
    glasgow
    i like the look of the autel scanners, i have a elm 327, op-com, and the renault clip scanner
    Mileage : 000
    I use an Autel Scanner. works ok for me.
  1. For Sale: rac fault code reader
    By david-bell in forum Parts for sale
    Last Post: 14th January 2013, 18:13
  2. fault code reader
    By richje100 in forum Engine & Drivetrain
    Last Post: 28th February 2012, 08:45
  3. fault code reader
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 21:05
  4. Fault code reader
    By Allblackdup in forum South Wales (RO - Vacant)
    Last Post: 30th March 2009, 16:03
  5. Fault code reader...
    By Green Growler in forum Troubleshooting
    Last Post: 5th December 2007, 16:04
