Thread: Quick amp/speaker question
    Liverpool
    Default Quick amp/speaker question
    The time has come to fit my new speakers and amp (weather permitting & how tired i am after nights) had them for ages but not got around to fitting them
    however i have a question or 2
    I want to run a small 4 channel amp for my door speakers but i still want the option of listening to the radio when ignition is off and amp(s) are not on, is it safe to wire the amp into speaker along with the original wiring so it will be amp'd with ignition on but can still be played whilst parked up (i know i can wire up to be on with stereo but i dont want to drain battery)
    Also with the power lead for amp, i already have 1 lead which is heavily overy rated for my current amp, can i just double up the wire and run a 2nd power cable to new amp? the inline fuse is in battery compartment but unsure if it would take the strain (amp wiring rated up to 520W), both amps are 250W so i imagine it would
    Thanks for your help in advance
    Liverpool
    Bump
    Mar 2011
    Rotherham
    only way you can do it safely is to have DPDT relays on every speaker and have them switch when the ignition is on to switch from the stereo feed to the amp feed
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    amps dont take that much power out the battery if they are only small ones and your not having it too loud so just have it on all the time, my corsa had a piddly little battery and i once had the radio on with the amp powering the sub and 2 6x9'f for about 1.5 - 2 hours and it still started fine, with the battery size the vecs have it aint a problem really and if need be start the car up every half hour for 10mins or so to give it a charge
    Liverpool
    Hmmm might just have a small amp then!
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Mileage : 166000
    250w is a small amp lol even 500w isnt mega, i had an 800w amp in my corsa lol, if your really worried make sure you carry some jump leads with you( i always do anyways) and some kind soul with give you a jump even if its a call of help to the nearest vec c member lol
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I'd go with everyone else, just wire it to the remote on, I mean there's rarely gonna be a time where you're listening to it at full pelt for over an hour... As long as your battery is good you'll be fine.
  1. a quick question
    By farley2708 in forum The 'Off Topic' room
    Last Post: 10th September 2011, 11:57
  2. Speaker wiring question
    By MattDC in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2011, 20:43
  3. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  4. Quick question
    By Keithy in forum Bodywork & Interior
    Last Post: 2nd November 2009, 22:15
  5. A question for any one using an Autoleads PC1-601 Rear speaker to RCA converter kit
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2009, 17:17
