Thread: SRI Springs
    Regular Member billwwhyte1's Avatar
    Nov 2010
    Fraserburgh Aberdeenshire Scotland
    Default SRI Springs
    Hi All
    Just had car in for MOT yesterday and failed on Fractured front spring, got both changed, Had a look at car this morning and seems so be sitting very high at least a inch or so higher than before, know they might not be settled in yet but could there be a possibility that they have fitted the wrong springs as i think a read in a post before that SRI springs are 15mm shorter than other type Vectras.
    Any info would be great before i go back to garage to find out what was put in..
    West
    Most likely they need to just settle, although if i were you i would ring them & ask exactly what did they fit
    East Ayrshire
    Trim : SRI XP1
    remember with a fracture you're old springs wouldve sat slightly lower. Also with wear etc. The new ones will be slightly higher, but will also take a few days to settle as said above
    Regular Member Jezzy's Avatar
    S.E
    Every time I read a post saying the new springs seem to make the car sit too high, (and I've read a lot of them), it's always an SRi. The SRi springs are indeed 15mm shorter than standard ones, and there's a good chance you've got the taller ones fitted by mistake.
    Nov 2010
    Thanks for reply's
    There any P/No's for the Springs as so i can check with garage to what the fitted..
    Regular Member Mopar Man's Avatar
    herts
    Have you got a pic?
    VX say there colour coded, but after market ones aren't
    I found that if there not VX, they probably aren't right. Must be for the correct weight of engine and year, chassis no etc. This does not seem to matter with after market?
    Nov 2010
    Springs probably from Dingbros not vx
    Nov 2010
    Springs are black in colour and from arch to top of tyre gap of almost 2-1/2"
    Front suspension, 1.9 CDTI 150, hatch, sports suspension, manual saloon :
    93182191 (to 71071977/48999999)
    93190536 (without IDS from 71012523)
    Would need to check against VIN though
    Jun 2011
    Fife
    Had exactly the same thing on mine, garage replaced one spring, it sat odd and then realised they had indeed put in the wrong spring, it had to be changed for an SRi spring
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
