Results 1 to 10 of 11
Thread: Rear boot lock sensor
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Rear boot lock sensor
    Hi all..Im struggling to stop the alarm going off when i drive off. It all started when i tried to stop the tailgate rattling.Sorted this but now the sensor wont stop going off when i drive off and i get the boot open sign in the dash..
    I've swopped the completre units over with a 2nd hand one. Same problem. Breaker refused to let me try another.
    Any ideas???
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    could be the wiring..
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Quote Originally Posted by kenp View Post
    Thanks for rthe reply kenp..tbh i thought the same but dont know how the check it out other than with a continuity test..
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    ok..got continuity on the wiring front..If i manually press the microswitch should his turn the boot open alarm/sign on the dash off??
    Engine : 2.2 Direct
    yes if it locks properly, and nothing is wrong
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    very good.....well it dont do anything and the wirings ok so..could it be anything else like a fuse or rela dya think?..i got an owners manual so fuses are oable but noo clue as to any of the relays..
    When I first got my car the warning continually appeared
    I then noticed that the boot closes but does not fully lock, as a result the mechanism reports open
    I made a small adjustment to the two adjusters and now the boot closes without any issue
    However, if I drop the boot slowly it still only catches
    If the boot catches and you are then able to press down and lock the boot then it still needs minor adjustment
    Turn each 1/4 turn each time
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Err two adjusters?....
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    The metal clasp that the boot locks down on can move over time due to the boot being closed. This can be moved by un-doing the two torx bolts that holds it in position they are under the trim on my siggy. Once loose slide the metal clasp thing up towards the boot door. this will alow the lock to lock down on it and close fully. This should fix your problem. If it is not locked down correctly you will get the diaplay on your dash and your numberplate light will stay on. You can adjust it a little at a time. keep sliding the clasp back till the lock is fully engaged. PM your no and ill talk you through it if you get stuck.
    Quote Originally Posted by nikroc View Post
    Yes open the boot and lift it into the raised position
    You will see an adjuster on each side
    I aligned them so that they were equal, by removing them and then counting the number of turns made, small adjustements were then made after that in 1/4 turns
  1. 2 probs: Park Sensor and boot lock
    By Jabbekot in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2013, 13:44
  2. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  3. Boot Lock
    By alancallaway in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2012, 18:35
  4. boot key lock
    By selv1980 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 07:31
