Thread: Air Cond Vectra 2005
    Dominican Republic
    confused Air Cond Vectra 2005
    Hi there
    a week or so ago, i noticed that my blower doesnt work on position 1,2,3 - other 4 speeds are fine, except there seems to be a massive difference between 1 and 2, 3 is a draught and 4 is a no work
    dont remember it being like this before - this is with the air con on and it is set to cool the main part of the car ie not the windscreen or footwells
    i have read about getting at the resistor and the other fixes available but these seem to only concern the fan working on 4 and not the other 3.
    any ideas?
    i Change resistor the problem is same.
    I've just lost 1 and 2 this evening, 3 and 4 work
    I've seen a few threads on this, so will try to find them, including a fairly easy fix
    Typical search fan 1 2 one two, and all of these are too short
    However, none of these seem to match my problem, the usual symptom is the loss of 1, 2, and 3
    Your issue sounds more like the thermal fuse :
    http://www.vectra-c.com/forum/showthread.php?t=134248
    http://www.vectra-c.com/forum/showthread.php?t=131055
    Sadly mine sounds like the Resistor Pack itself has failed
    When daylight arrives I will revisit the entire area, presumably a small amount of water is passing through
    Engine : 1.9 CDTi
    The resistor works by resisting the output through it to alter the speed.
    Full speed is a direct connection and not through the resistor so if only full speed works its the resistor.
    Quote Originally Posted by lee gsi View Post
    Not sure your description is correct, or its the way you've written it, as there is a difference between resistors (within the pack) and thermal fuse (which is external, but still attached to the pack)
    There are at least three resistors in the pack, if any one of these fails then the other speed settings will work
    In my case two of the resistors have failed, resuling in 1 and 2 not working but 3 works
    However, there is a thermal fuse that covers all three
    If this fails then all three (1, 2, and 3) will not work
    Dominican Republic
    i change the resistor the problem is same... no work other speed only No.4
    Removing the glovebox was easy enough
    Access to the resistor is poor
    Initially I detached the resistor and found it would not come free
    Therefore my advice is to unclip the black electrical connector first
    The resistor will then fall free
    On removal mine had simply corroded internally
    No external water and the area was completely dry and clean
    Refitting is the reverse, but locating the resistor requires a good push to click into place
    Whilst I had the glovebox out I also removed its damper as this failed ealier in the week
    On removal I found it was working so refitted it
    Strangely it didn't work
    I removed it a second time and pumped it a few times, to which it gave a loud bang (similar to the noise when it failed), then refitted
    Now it is solid, but better than falling like a cupboard door!
  1. For Sale: Vectra C 1.8 2005
    By mattster87 in forum Cars for sale
    Last Post: 8th February 2012, 15:26
  2. just got my dad a 2005 vectra
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2011, 14:36
  3. My 2005 Vectra SRi
    By rob10 in forum Quick Photo Album
    Last Post: 25th February 2011, 16:28
  4. Vectra GSI 2005
    By Bloicy 3.2 V6 GSI in forum Cars for sale
    Last Post: 31st May 2009, 21:32
