Thread: Swirl Valve bar has come off
    Regular Member coooky's Avatar
    May 2011
    washington
    Default Swirl Valve bar has come off
    I have read the how 2 but i need a little help
    i read the problems people were having was the car going into limp mode and driving sluggish
    my car is driving fine but im still going to do the mod what i need to know is there are black grommet looking things on the engine do im leave these in place and clip the bar back onto theses once the mod is done also do i clip the bar back in any sort of order ??
    what sort of damage happens with the bar removed how much is new part if i plan on keeping the car long term i will replace with a new one i read around £250 plus labour is this right and is it a stealers only part ??
    also whats the part called ??
    cheers
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Yes leave the round swirls alone!, fit the tap washers or plastic caps to the bar, Then place over swirls guided by fitting the third one from the left first (thats the motor driven one) the rest are loose & will move into line with the aid of a screw driver.
    Regular Member Jezzy's Avatar
    S.E
    This is the replacement manifold you would need if swapping it out, as you'll see it's available for much less that £250:
    http://cgi.ebay.co.uk/Vauxhall-Induc...item2eb619d158
    Jun 2011
    Liverpool
    its worth doing the actuator while your at it incase that fails in the future.
    i recently had a quote for supply and fit of £ 800.
    he wanted to do the timing belt while he was at it.
    Ive decided to give it a miss for now as dont think it would make much difference to performance, i may be wrong.
    May 2011
    washington
    Thanx guys for the replys
    Quote Originally Posted by c4rlos View Post
    anyone got a link to the actuator for a price ??
    will also be getting the timing belt done as i dont know when if at all its been changed
    Mar 2013
    erith
    Vehicle : wauxhall
    Trim : vectra
    Engine : 1.9ctdi
    There is a link www.swirlrepair.com is a cheapest way to fix intel manifold swirl flap bar
    . Only 37£ and it works fine, I fited on my one.
    Dec 2010
    Cambridge
    Vehicle : VectraC CDTI 150
    Year : 07
    Mileage : 175000
    Genius !
    Apr 2011
    Norfolk
    In my experience the swirl valve bar came off but the actuator was still functioning as i could observe #3 valve turning, the motor is connected directly to this valve arm underneath the inlet manifold. This kit would have only been a short term measure, as when i removed my inlet manifold it was absolutely full of rock hard carbon and crud so my thoughts would be that the ball joints are exposed to excess stress due to the valves being blocked up, thus being harder to turn.
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
valve swirl off
