Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
Thread: lumpy tickover z20net
    Worksop
    Default lumpy tickover z20net
    any ideas on this no codes up
    Regular Member benny's Avatar
    Feb 2006
    dudley
    any rattles and so on
    Worksop
    no its spot on mate plenty of power just lumpy running
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    i have this at the moment as well mate, i quickly wiped the inside the throttle body (not a proper clean/wipe) and it settled it back down.. I plan to give it a proper clean out this weekend, there was not much dirt in anyway, i only really wiped the edges of the butterfly valve so far and noticed a difference.. try it, its a free easy fix if it works for you.. nothing to loose
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you checked all the intake pipes/hoses are secure/tight?..sounds like an air leak.
    May be worth you taking off the main intake hose and cleaning the throttle body with carb cleaner and a toothbrush
    Worksop
    Quote Originally Posted by nikroc View Post
    yeah thats my plan as ive got silicone hoses to fit any thing else i can clean to help
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I've also sprayed carb cleaner down the intake pipe ,after the maf..n sumat like redex run thru it for good measure..
    Ohh n id have someone helping you wen u clean the throttle valve..ie after you,ve sprayed/used the toothbrush method(both sides of the plate and anything else you can see)get the person to start car,it may keep on stalling, whilst you spray cleaner through..
    Amazing amount of white smoke n crud outta the exhaust!!
    N i use the real cheapo carb cleaner from screw fix..
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    did you sort this lumpy ticker over issue yet mate?
    Worksop
    no nige still doin it found my lambda sensor in engine bay were loose thought id fixed it but no its same going to swap the sensor tues see if it sorts it
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    keep us updated on how you get on, seems to becoming a common thing..
  1. Really lumpy on tickover
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2012, 21:48
  2. vectra 2.0 turbo z20net lumpy idleing (can anybody come help )
    By matrix1979 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2012, 23:22
  3. Lumpy tickover
    By Alansvecky in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 20:25
  4. z20net lumpy idle running rough
    By tomo41 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 23:06
  5. Tickover
    By sri150 in forum Engine & Drivetrain
    Last Post: 26th June 2011, 18:47
z20net sludge
vacuum pump rattle z20net
z20net exhaust gasket problem
vectra c Z20net p0420
