Results 1 to 10 of 13
Thread: P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Unhappy P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    Afternoon everyone.
    Just looking for qick response here as this is my own fault.
    I has my inlet manifold off today for a full de-coke and I could not get the EGR off. I tried everything including a 20 min drive to warm it up. I gave up after 30 minutes when I snapped off the upper right mount of the EGR.
    I did clean the manifold and its really clean. Obviously the EGR is now kinda dead. I get P0400-F8 as the title. Is this the valve that's gone or something else? I've read ages ago but can't think where that the P0400 code could be a manifold sesnor not picking up the difference in pressure.
    I've ordered a new EGR £320 best I could find and that hurt. Should I just replace and hope or maybe another sensor and I've wasted over £300?
    This thread says I can cut my sensor wire. I think this is a bad idea.
    http://www.vectra-c.com/forum/showthread.php?t=95561
    Thank you.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    P0400 is your egr valve fault code
    £320 is a bit steepfor a egr try this link £199 is the best offer on here
    http://shop.ebay.co.uk/i.html?_nkw=v....c0.m270.l1313#
    Engine : 2.0DTi
    Mileage : 73350
    Apr 2011
    Somerset
    Quote Originally Posted by bobssignum View Post
    Hello. Thanks for the info on ebay. I did have a look earlier and couldn't see anything that I could get quick for under £270. Thanks to your link I have now ordered one at £226 with delivery on Tuesday pre-10am and cancelled the order with Unipart.
    Is my EGR totaly gone or salvagable?
    Engine : 2.0DTi
    Mileage : 73350
    If it is the water coolant hose that has broken then probably yes it is not salvageable , If you can post a pic of the broken part would help to clarify the situation
    Apr 2011
    Somerset
    Here we are. Taken today, note top pipe missing and right lug snapped off. Error seems to point to feedback problem though???
    Apr 2011
    Somerset
    Here is the other bits of the valve that came off while trying to get it off.
    Engine : 2.0DTi
    Mileage : 73350
    yes i would definnetly say that your egr should be replaced , what did you hit it with a sledge hammer ?.
    scottish region
    what engine is it as thats seems expensive i got ming new £80 for 1.9 cdti
    Apr 2011
    Somerset
    Quote Originally Posted by vectrac150cdti View Post
    Chaps,
    It's a 2002 2.2DTI Y22DTR.
  1. P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    By lencuff in forum Y & Z30DT Specific
    Last Post: 20th November 2012, 18:15
  2. Fault code po403 exhaust gas recirculation valve.faulty.
    By Dobs in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:37
  3. P0400 - EGR Flow Malfunction
    By BigMart in forum Engine & Drivetrain
    Last Post: 30th May 2011, 22:07
  4. P0400-5B Exhaust Gas Recirculation Flow Excessive Detected
    By zafira in forum Diesel Engine related
    Last Post: 11th September 2010, 07:46
  5. Exhaust Gas Recirculation Flow Malfunction
    By H0885 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2009, 20:20
exhaust gas recirculation valve feedback signal malfunction
p0400-f8 vectra c
P0400 signum 2.2 dti
code po400 vauxhall vectra 1.9 cdti 2007
p0400 fc vectra c egr sensor malfunction
P0400 opel vectra 2.2 tdi fault code
astra code po400
opel zafira egr feedback signal
po400 vectra cdti
egr feedback
Opel P0400
vectra c fault code p400-f8
Signum Y22dtr p0400
vectra c 2.2 dti exhaust gas recirculation malfunction
vauxhall vectra 1.9 cdti p0400
vauxhall signum 2007 egr signal
p0400 vectra c 2.2 dti
vectra p0400-f8 exhaust gas recirculation valve feedback signal malfunction
vectra c po400-f8 exhaust gas recirculation valve feedback circuit malfunction
vectra c fault code p0400
astra y20dth fault code p0400 open
