Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi with ref to my vectra 2.0 dti i have put another egr valve on and ithas still got no power and spanner light comes on any body got any ideas thanks
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Under what conditions does the engine management light come on? Motorway speeds? Only when up to temperature etc? Failing getting the codes read off by a garage, stabbing in the dark really.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    As said unless you know what code it is it could be anything. I'd say look at the vacuum hoses and intercooler hoses next, but the code will pin point the issue.
    Jan 2010
    norfolk
    cheers for replies had codes read and came up with egr valve 2 codes , bloke who read codes is vauxhall mechanic and iv already put secondhand valve on so he said could be naff valve again or airflow meter does this sound right thanks
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
