Thread: Low Power, Wont Go Above 3000 Revs
    Jun 2011
    Basingstoke
    Exclamation Low Power, Wont Go Above 3000 Revs
    Vectra 1.9cdti 120 - 07 Plate
    Eml light has come on again so used a code reader and got p1125 which associates with throttle body so i stripped it down gave it a good clean and reassembled it but still no diffference.
    im not convinced this is the problem so if i give the symptons maybe someone can identify the issue.
    9 times out of 10 drives fine no problems whatsoever but occassionally driving along and feels like there is little power or more like there is no turbo, when its floored it wont go above 3000 revs ?
    Like i say its only occassional but very annoying, Any idea's ??
    Also just to point out that the eml light comes and goes and is not always on.
    Jun 2011
    Basingstoke
    just to add to the above that the egr has been replaced with a new one so i don't think this problem is linked at all.
    Jun 2011
    Basingstoke
    Been Browsing The Forum And Found The Fault Code P1125 As Throttle Position Sensor Intermitant, So this im guessing is not the throttle body ?
    If this is a sensor does anybody know exactly where it is and if it can be fixed or just need replacing.
    Jun 2011
    Basingstoke
    Anyone ?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Could be the accelarator pedal assembly?
    Nov 2009
    Norfolk
    Its a diesel, they dont generally go over 3,000rpm
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    we're not talking about YOUR farmer tractors lol
    Jun 2011
    Basingstoke
    Any other ideas apart from the fact its a diesel ?
    Jun 2011
    Basingstoke
    found out its the throttle body electrical component has dry joints inside aswel as a load of oil !
    Ordered a new one today, if anyone has any idea how oil got inside i would be very grateful to know ??
    Jun 2011
    Basingstoke
    Blown Gasket In The Centre Pipe Allows Smog To Enter Lower Throttle Body Electrical Housing Which Then Builds Up And Knackers It And Then Looks LIke Its Full Of Oil, You Can Normally Drain It All Out And Give It A Good Clean And Check All Solder Pins Are Not Cracked If They Are Re Solder Them And It Should Work Fine.
  1. vibration after 3000 revs
    By lordreeson in forum Engine & Drivetrain
    Last Post: 25th February 2011, 13:57
  2. HELP!!! Engine Pulsing and wont go over 4k revs!!
    By sub2199 in forum Engine & Drivetrain
    Last Post: 6th December 2010, 10:26
  3. Limp mode in 3rd 4th and 5th at just under 3000 revs
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 19th July 2010, 15:48
  4. Just lost all power at 3000 rpm on 3.0 V6 CDTi
    By neverton in forum Engine & Drivetrain
    Last Post: 24th May 2010, 12:27
  5. Replies: 11
    Last Post: 7th January 2010, 17:50
vectra 1.9 sri cdti wont go over 3000 revs
vauxhall insignia wont go past 3000 revs loss of power
vectra revs will not go above 3000
vauxhall insignia 3000 revs
vauxhall vectra turbo not going past 3000 revs
vectra wint go over 3000 rpm
vectra cdti 120 p1125 www.vectra-c.com
vectra c low power
vectra rpm wont go over 3000
vectra c sri 150 stops at 3000 revs
my vauxhall insignia wont go passed 30 revs
vectra c 1995 diesel wont go over 3000revs
vauxhall vectra 1.9cdti not going over 3000 revs
