Results 1 to 10 of 19
Thread: Strange uneven rear tyre wear!!
    Aug 2009
    north east
    Default Strange uneven rear tyre wear!!
    Hope someone can help. I have strange tyre wear on my rear offside tyre, it is wearing in a sort of chevron pattern across the tread but with 4 to 5 cm spacings.
    I'm also get a strange whopping noise from the wheel at all speeds. My thinking is worn bush but it's deciding which one?? I'm a big beleiver in doing work myself if i can as a money saving device but really don't want to change all of them. Plus how hard is it to change them?
    There is no rim rock when i jack the car up so don't think it's the bearing, I'm just at a loss, any and all information/advise is always gratefully received.
    Sounds like shock absorber failure
    Have the entire rear suspension checked, report on any play or worn components
    Aug 2009
    north east
    Bump
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    when was the last time you had the tracking checked bud
    As previous, has the rear suspension been fully checked yet?
    On the rear?
    Incorrect rear camber would give you a consistent wear pattern, not patches (often called scalloping)
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Are they Falken tyres by any chance?
    Before you spend loads of money and time on bushes, try another set of tyres or wheels. Had Falkens on mine and from the time I fitted them, it sounded like all the wheel bearings had gone. Tried another set of wheels and the noise had gone.
    Worth a try.
    Paul.
    Snowman, you got your ears on?
    Aug 2009
    north east
    No not falkens and had no problem up until recently. And as said above it would be scrubbing the tyres off in a constant fashion if the tracking was off. I gave my rear end a good going over and couldn't find any excessive play or worn/damaged bushes or parts. Not really sure how I can check shocks?
    Quote Originally Posted by maximus8425 View Post
    Several ways to do this
    Normal method is to bounce each corner, but the Vectra has quite stiff suspension so it is near impossible
    However give it a try, simply place all your weight on one corner and check that the vehicle returns to its original height, and it doesn't bounce like jelly
    Firstly some questions
    Are you getting knocking noises from the rear?
    When passing over a speed bump does the back of the car bounce across the car unevenly (left - right or right - left)?
    Clean the shock absorbers throughly then leave for at least 12 hours (the longer the better)
    Check for leaks, starting at the top
    Finally, have someone drive behind the affected car (ideally with virtually no other or no road users)
    Ideally find a road that is straight and flat, a two or three lane dual carriageway is best
    Watch the rear wheel and watch for it bouncing at specific speeds, starting at 30mph, 40mph, and 50mph, then repeat for the other side
    Aug 2009
    north east
    No there is no noise when I drive, just the strange whopping noise. And no uneven bouncing or movement while driving. I'll give the tyre bouncing a go when I drive and see if anyone can see movement. I had thought of swapping the shocks over on the rear after checking for leaks and see if the noise literally switches sides as i imagine it might if the tyre is bouncing. Cheers
    Max
    Apologies, missed this noise
    This will be created by the tyre (as the tread depth varies and create harmonic vibration)
    If possible try to determine which side the noise comes from
    Ask a passenger to sit in the rear, roll the windows down, sit in each side and see which is worse
    Where did you obtain the tyres from? (supplied and fitted by the same agent?)
    What tyre pressures are being used?
    What make and specification are the tyres?
    Have these tyres always been on the rear, for how long and how many miles?
    How much tread is left?
    If possible take various measurements, like a clock face and across the tread , giving you 12 measurements per tyre (NSR and OSR) :
    12 A B C
    3 A B C
    6 A B C
    9 A B C
    Where the number is the clock face position and ABC are the tread facing from outside (A) to inside (C)
  1. uneven and serrated rear tyre wear
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2012, 02:28
  2. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  3. REALLY uneven tyre wear
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2010, 23:25
  4. Uneven tyre wear
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 15:16
  5. Major Uneven Wear on Rear nearside Tyre
    By jamieclarke in forum Suspension, Wheels & Brakes
    Last Post: 7th June 2007, 19:22
vectra c rear tyre wear
uneven tyre wear on rear wheels
Why does a 09 vectra wear the rear tyres unevenly
