Thread: Signum headlight washer jet covers not returning flush
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Default Signum headlight washer jet covers not returning flush
    Nothing in the owners manual so thought I would ask on here.
    My Signum has AFL with xenon headlights and so has headlight washers, after washing the jet covers sit proud of the bumper and don't return flush unless I push them down. Do they have a time delay or is there something wrong with the return mechanism?
    Thanks in advance
    WGAF#5
    sounds like an issue.... they should return after use
    Jun 2011
    Skegness
    Anyone know how they should return.... are they spring assisted?
    Spring inside the mechanism which is pushed against by the water pressure from the pump to cause them to open. Always did it when I had the car mate, never got round to looking into it that deep if I'm honest...
    One option is to remove the bumper partially, and tip it forward so you can prize off the washers and see if the work properly when not attached to the bumper itself..
    Jun 2011
    Skegness
    Cheers Martin, Have squirted some WD40 down the washer stems and worked them in and out by hand, go back easy enough by hand, but would like them to do it by them selves, cheers
  1. headlight washer covers
    By Angel1368 in forum Styling
    Last Post: 29th April 2012, 14:30
  2. Replies: 23
    Last Post: 27th July 2011, 20:07
  3. Headlight washer covers....
    By johns159 in forum Insignia car chat
    Last Post: 27th April 2011, 16:21
