Thread: Drivers Door Lock Switch Help
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    Default Drivers Door Lock Switch Help
    Can anyone help with the following:
    The drivers door lock button still wont work.
    Originaly there was a few switches not working (including passenger side) but took them apart and cleaned them up. All buttons work fine now except the drivers door lock.
    Any1 got a clue of a way to fix this?
    Would it be the module? A damaged wire? or something more simple?
    Really annoying me as I cant turn on anti hi-jacking or lock-unlock doors from it.
    Thanks in advance
    Jun 2011
    Dublin
    Any 1?
    Jun 2011
    Glasgow
    try a continuity test, see if you can get a transfer of electroncs from one part of the switch to the other, if its resistence is infinite then the switch is busted
    you have a multi meter??
    Jun 2011
    Dublin
    No, got no muti-meter
    Could borrow one from a friend(electrician).
    Ive try'd crossing the switches when its apart but still no luck.
    Would there be anything else a miss or is it more than likely a broken switch.
    Thanks 4 reply
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    hi
    i can tell you that the drivers door lock controls the whole car alarm system and door switches I had to have mine changed as i had your problem luckily the car was under warranty (i believe it cost £100 All in)
    Jun 2011
    Dublin
    Must try putting a new switch in.
    Cant think it'd be anything else other than the switch itself apart from the wires.
    I'll try a few scrap yards, might get lucky.
    Cheers 4 reply lads
  1. drivers door lock
    By eddy b in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2011, 06:24
  2. Drivers Door Lock not working
    By Rupster_69 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 16:07
  3. De-lock Drivers Door...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:43
  4. Drivers Door lock problem
    By r3m0dul8 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 10:43
