Thread: V6 cdti 3.0lt diesel
    Aug 2009
    wick
    Default V6 cdti 3.0lt diesel
    Hi the alternator belt is needing tightened on my V6 Signum can anyone tell me what this involves there is also a swhishing noise from it so it could need a new belt any help would be good
    Thanks Rob
    Full Member Big Sig's Avatar
    Its got an automatic tensioner, so at a guess its a new belt and tensioner thats needed.
    Mark, you've just done this Care to comment?
    lol your not wrong sean
    right the symptons you say basically mean you will need a new belt and tensioner
    first thing
    draw a picture of the belt location so when you come to refit it you get it right
    to remove belt
    15mm socket on a long ratchet , put the socket on the nut on the tensioner , turn this anti clockwise and this will remove the tension from the belt
    remove belt from tensioner and rollers etc
    to remove tensioner
    the tensioner is held on with 2 x 6mm allen bolts , undo these and the tensioner will come away easy
    refit new tensioner and tighten 6mm allen bolts up really tight
    when refitting the new belt its prob easier to have 2 people ,
    one to hold belt over the rollers and other to do the tensioner part
    rethread new belt over all pulleys and guide rollers except the tensioner making sure that the grooves on the belt line up with the grooves on the pulleys that have them
    with 2nd person holding belt in place , use the 15mm socket again and turn tensioner anti clock wise with one hand and when low enough push the belt up onto the tensioner roller
    release tension so belt goes tight
    check belt it located properly
    start vehicle , smile , scratch nuts and stand back and admire handy work
  1. Diesel Purge - CDTI 150
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 12th January 2013, 21:52
  2. 1.9 cdti 150 + £30 of diesel
    By rickisgrate in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 01:36
  3. 150 cdti drinking Diesel
    By ash..r in forum Diesel Engine related
    Last Post: 1st November 2010, 18:39
  4. 80.2 mpg and even more Bhp,Nm from 3.0V6 CDTI lpg diesel mix
    By Tibbs1cat in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 16:55
  5. Never Buy A Vectra Cdti Diesel 1.9
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2007, 19:36
