Thread: Full brake bleed
    Chelmsford
    Default Full brake bleed
    Hi guys, already posted about this but now can't find the thread so trying again.
    Want to do a complete bleed of my brake system, including the ABS pump.
    Anyone done this using OpCom? Any advice for me?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Did mine last year, simples..used easy bleed system. No opcom,no problems.I believe that it also bleeds the clutch system.Bleed nipples inside engine bay.
    TIP: Id spray all the bleed nipples in wd40 way before you try n move em.
    TIP:Before you try and undo the nipples,very slighty tighten them,this in essence cracks the 'seal'.
    TIP: Make sure that you have the correct sized spanner for the nipples,I also used a deep socket on mine.
    did it on the siggy on monday
    believe its a 10mm spanner required
    i used one of those one man bleed tools that attaches to an airline
    took about 15 mins from start to end
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    DON'T EMPTY THE SYSTEM!!!!! I learnt the hard way once upon a time while renewing the brake fluid... :P
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    easy bleed system, very usefull and no hassle
    Chelmsford
    Done the bleed before, but I have a feeling that dirt may have ended up in the ABS pump which is causing the problems I'm having.
    I know you can use OpCom to open the pump valves and flush the whole lot, but not worked out how yet...
    Cheshire
    Quote Originally Posted by luke4487 View Post
    i wanted a complete change of fluid so i released all the fluid at every bleed point!!
    Then refilled it, then and bled it, perfect but it seems i was very lucky! it only took about 500ml
  1. Brake bleed sequence
    By mungo1985 in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2012, 16:14
  2. Brake bleed sequence
    Last Post: 23rd January 2009, 05:37
  3. Brake bleed problem? on new upgrade.
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2008, 16:33
  4. Brake and Clutch bleed
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2008, 20:21
