Thread: exhaust condition and heat shield
    Jun 2011
    blaydon on tyne
    Default exhaust condition and heat shield
    Mot picked up on problem with back boxes, corroded, yes one heat shield part not there and other back box rusted and loose so now ripped off,
    anything you can paint on or any kind of protector to stop the back boxes rusting away?? or is it a wait til they die then replace?
    prob not too cheap for the twin boxes??
    chesire
    mine was the same so i ripped off the offending piece and now its just a case of waitin till it drops off then i will get a new one !
    i think vauxhall made em out of quality street tins
    Jul 2010
    Warrington / Liverpool
    you could use that kurust stuff to treat any rust, assuming the box is still sound now and not full of holes... Then paint it or get some cold zink spray or something like that
    Jun 2011
    blaydon on tyne
    yeah the exhaust itself is in ok condition, heat shield like mentioned above....ripped off before it done someone an injury but the box is alright, just wondered if there was anything like underbody protector kind of stuff but for exhausts would just a high temp paint be ok you think?
    then..... is this just a p;ointless task as being its an exhaust, will it be rotting from the inside out
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Ive used some of screw fix's rust inhibiter to very good effect for a while now,same as branded only cheaper and you get more..
    Actualy used motorcycle exhaust paint and even barbaque paint on exhausts!!!
    BTW it was over £200 cheaper to get 2 stainless steel back boxes custom made than it was to replace with oem.
    Jun 2011
    blaydon on tyne
    Quote Originally Posted by nikroc View Post
    How much is it for the vectra c backboxes twin exit exhausts ?? think i may be buying some paint soon
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    On my 2t it was approx £530 4 years ago
    Jun 2011
    blaydon on tyne
    FOR SALE !
    better get me self on a stainless welding course then....
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    custom made,cat bak with a middle box and two boxes..£380ish...i cud ask how much itd be now. I been using the garage for 25 yrs.
    As mentioned previously, the securing points on the VX range for the heat shields is very poorly designed
    The first thing I do when I take ownership is to unscrew each nut head, insert a large washer, and then reinsert the nut
    All too often I follow other VX cars and see the heat shields hangin loose or even free, sitting on top of the exhaust or silencer
  1. heat shield
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th May 2012, 02:11
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Heat shield.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2009, 22:37
  4. Heat Shield
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2008, 22:12
