Thread: Oil Change
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Oil Change
    Needing To Do An Oil Change/Filter/Plugs..
    Do I Just Change The Oil Or Do I Flush It ?
    Never Flushed Before..Dunno Anythin Bout It...Just Seen It Mentioned On Here
    Regular Member charliedub1's Avatar
    Jun 2011
    Ireland
    Quote Originally Posted by Tam80 View Post
    No mate, Just change the oil. Imo I wouldnt be flushing it unless the oil was comming out in lumps! It wouldnt really do any harm but wouldnt really do much good either.
    The couple of quid you would spend on a decent flush, just upgrade the oil your gonna put in
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by charliedub1 View Post
    cool cheers charlie..i got good oil there to put in it
    Devon
    If it's been changed recently (within a year) and the engine has had regular changes all it's life, then I wouldn't. If not then I would drain, run some fresh cheap oil for a week, then do the proper change with filter and decent oil. This will make sure all traces of the old oil is removed.
    Regular Member Jezzy's Avatar
    S.E
    Definitely don't do the engine flush. The problem with it is that it's only suitable for engines where the flush has been used during all the oil changes that the car has ever had. If the engine has never been flushed before and the mileage is now more than, say, 35k+ then it's too late to start using it, and it can do much more harm than good. Lumps of old oil will have built up inside the engine and these are harmless if they're left where they are. The flush will dislodge them and cause the oil ways to get blocked.
    Those that know engines inside out say that if you've never used a flush before, then it should only be used on an engine that has terminal problems already and the flush is used as the last resort before consigning the engine to the scrapheap.
    north east
    As posted above just change the oil for fresh, if its really bad change it again after a month / 1000 miles.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
