Thread: Hillman Imp Renault 5 Gt turbo engine fitted
    Jan 2010
    glasgow
    Default Hillman Imp Renault 5 Gt turbo engine fitted
    0-60 in 6 sec got to love old school
    http://forum.theimpclub.co.uk/viewto...p?f=33&t=18082
    Feb 2011
    Selby
    Excellent. I've got two Renault 5 GT Turbos (one's a project, not currently running), and a spare engine/gearbox if anyone fancies putting that good old bulletproof C1J788 engine into anything. You can't beat a nice sturdy iron blocked 8 valve carb engine with a turbo ramming air in at 20psi
    Norwich
    Trim : SXi
    Engine : 2.2
    Hillman imp was designed by a 5 year old child asked to draw a car lol
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Sturdy and gt turbo in the same sentence? Lol
    Thought that engine was plagued with problems particularly the Hg?
    Feb 2011
    Selby
    No HG issues - unless you never change the coolant, or run stupidly high boost pressures without taking into account that things will get hotter, so you need to make sure the cooling system is working properly.
    Got a bad press in the early 1990s where kids where just whacking the boost up and not doing anything else. The standard cooling system is easily up to the job, but not if the coolant in it is what it left the factory with back in 1986!
    Regular Member Jezzy's Avatar
    S.E
    I distinctly remember they had hot-starting issues; although I did think the Raider special edition was quite tasty.
    Feb 2011
    Selby
    Yes, I won't argue with the hot start problem. Though if it's a 1989 or later it has an 'anti-percolation' fan which blows cold air through the intercooler and carb after engine switch off to help prevent all the petrol in the carb evaporating. Assuming the sensor that sits close to the turbo hasn't melted, this does work quite well.
    My black GT Turbo has never really suffered from hot start issues, except on track days or when drag racing (ie a lot of sitting around with no airflow), but my yellow GT Turbo does suffer a bit in hot weather. It doesn't have the fan though, so I'll get round to fitting one at some point.
    S.E
    Post '89 cars? Those are the "5 extra BHP due to closer manufacturing tolerances" and "badge moved a little to the side" cars..?
    Feb 2011
    Selby
    Phase 2 GT Turbos have a different camshaft profile and turbocharger to Phase 1s. The torque band is a little wider so slightly less likely to catch you out on a wet corner and put you in a ditch as the turbo spins up, the front wheels lose grip and you torque steer into a ditch.
    Oh yes, it's a car you have to concentrate to drive! No power steering, no ABS, no traction control, and only 850kg front wheel drive.
    Lots of fun, but can be frustrating as with any 1980's car.
    Feb 2011
    Suffolk
    You obviously know what your talking about! I love the gordini turbo wide arch, awesome!
    My r19 16v had anti percolation. Killed to batteries CID of that lol. And it always made weird gurgling noises
  1. front splitter fitted to the 100 turbo
    By tomo41 in forum Quick Photo Album
    Last Post: 22nd June 2011, 08:54
  2. Vectra turbo vs Renault clio Sport......not happy!
    By benholden2010 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 17:30
  3. Anyone fitted an Insignia Vxr Turbo to their Veccy?
    By luke4487 in forum Petrol Engine related
    Last Post: 26th June 2010, 14:37
  4. 2.8 cone filter/turbo gauge.. anyone fitted?
    Last Post: 29th November 2009, 00:30
  5. diesel engine... help. (renault)
    By 2ltrT in forum General Chat
    Last Post: 29th January 2007, 09:02
