Results 1 to 10 of 23
Thread: Q about lowering springs
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    Default Q about lowering springs
    hi all
    please let me know what you think
    i went to my local parts shop and they gave me 2 options on the same springs 1: is weight up to 1000kg
    or 2: is weight over 1000kg
    so...
    i am thinking if i go for OVER 1000kg it should be a bit harder and stronger , Am I Right ?
    West
    Being an oilburner you will need over 1000kg... you can see the weight loadings by opening the drivers door & look on the plate which is located on the pillar.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quite a lot of people on here who bought Eibach lowering springs choose the under 1060kg springs.
    purely that if you bought the next size up over 1060kg the car wont sit as low as if you buy the under 1060kg ones.
    swansea
    Assuming the springs are all the same length, then they should drop the car the required amount. Otherwise you will be buying springs that are too hard or soft for your particular car.
    Apr 2011
    London
    thanks for that
    i am thinking of going for apex -35 mm drop
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by smirnoff sri-dti View Post
    thanks for that
    That will be a 20mm drop as your car is already -15 as its an Sri
    Apr 2011
    London
    surely it will look good with 19" and this springs
    Vehicle : SRi
    Mileage : 137000
    Yes mate, will look spot on
    Jun 2011
    Herts
    avoid the local prts shop it the springs are not listed as being for your vehicle. over 1000kg is not really accurate enough IMHO.
    the apex or similar will be made to suit your cars weight which I'm guessing is 1060/1065kg on the front and 980kg on the rear like all the vecs (vxr 985kg)
    pics when its done please ;-)
    Apr 2011
    London
    will do
  1. lowering springs
    By mvl41183 in forum Handling & Braking
    Last Post: 23rd December 2011, 23:20
  2. lowering springs
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 14:56
  3. Lowering springs...
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:33
  4. Lowering springs
    By parsco in forum Handling & Braking
    Last Post: 14th September 2010, 21:50
