Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Is it legal?
    Jun 2011
    London
    Default Is it legal?
    Hello,can someone tell me if fitting hid kit on to 52reg car is legal and is there a MOT complecations,please?!Thank you.
    Sep 2010
    not legal if the car doesn't have auto levelling for the lights and headlamp wash system fitted. This applies to ANY car and not just a 52 plate car. Currently there are no issues with HID lights and MOT's other than ensuring the beam is set correctly.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by chewy71 View Post
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    there is a thread going at the moment where someone failed the MOT due to hids
    ignore this it failed on beam alignment
    Regular Member Rorschach's Avatar
    Jul 2010
    Midlands
    I think if you have projector lights and assuming they're the correct level, it's perfectly fine and looks OEM. The problem is when you have HID's in light clusters that are not designed for that level of light... take the Astra H for example. It doesn't have the projector lens as standard and thus, spreads the HID light out so far that it blinds everyone. I ran into someone with this problem (although it was on a MkIII Golf) and he told me he gets pulled all the time - yet he still hasn't taken them out... I had the misfortune of driving him somewhere while he was following, and my eyes felt like they were bleeding.
    Jan 2010
    York
    Quote Originally Posted by Rorschach View Post
    My Carlton has HID headlights retro-fitted, passed MOT's for the last 7 years and do not dazzle AFAIK.
    Obviously it depends on the lens (if reflective), choice of bulb (mine are 6000K) and beam pattern.
    6 Post(s)
    take the Astra H for example. It doesn't have the projector lens as standard and thus, spreads the HID light out so far that it blinds everyone. .
    In which case you pay the little bit extra and fit the correct HID bulbs which have the blackout cover on top of the bulb (H7R instead of H7 - that is of course if your particular car uses H7 bulbs). In the real world however people without projector lights don't bother and end up blinding everyone else and give HIDs a bad name.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Make sure the beam is set right, I just learned that.
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Whilst not legal, as long as your beam pattern remains the same you should be fine. Checking HID fitted cars have self-levelling light/suspension and washer jets is not part of an MOT test. To have HID's a car must have projector type lenses (which Vectra's are fitted with as standard.)
    What you should do is whilst fitting, draw your original beam pattern on the wall (in pencil!), fit your HID's, and compare and adjust.
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    if they are fitted properly, aligned correctly and u make sure you set the headlamp level switch correctly and that the headlamps are kept clean they wont cause you a problem with the law or the mot tbh. technically they are not legal without levellers and washers but i cant see any decent copper being too bothered if you are being responsible about making sure you dont blind other people
    South East Region ARO And Resident Diesel Head
    Owns: 2005 Vectra Life Hatchback 1.9 CDTI 150 Mods: Too Many !!!
  1. What Is Legal
    By Tam80 in forum The 'Off Topic' room
    Last Post: 9th August 2011, 22:31
  2. Are these legal?
    By mick.n in forum Styling
    Last Post: 20th October 2010, 15:27
  3. Are these legal??
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 20:37
  4. Are these legal?
    By ALD in forum Styling
    Last Post: 2nd March 2007, 17:07
  5. Legal?
    By blr123 in forum General Chat
    Last Post: 27th February 2007, 21:00
