Results 1 to 3 of 3
Thread: clarification required for f40 gearbox
    Default clarification required for f40 gearbox
    right story goes
    doing o/s cv gaitor this morning before changing gearbox oil in the siggy
    when i pulled the drive shaft out of the box obviously the fluid came out
    went to remove fill plug on top of gearbox ....... wouldnt shift , stuck fast
    bit of sweating and several different tools later got it off
    replaced driveshaft into gearbox and bolted it back in
    now the fun bit.....
    cannot for the life of me get the drain plug out of the gearbox its stuck fast and just rounding off so i thought
    not that much of a problem most of the fluids out i can just top it up with whats missing
    the question is ...... how much oil is in the gearbox to start of with
    i know i should put 2.4 ltrs back in and i could do that if i could drain it but i cant get the last bit out
    i measured what has come out and its 2.8 litres
    now im under the assumption that originally there was 3.2 ltrs in there so that would mean that i only had to add 2 litres
    is this correct ?????
    thanks for reading
    Aug 2010
    Derbyshire
    That sounds about right, what I would do.
    Just done mine and put 2.4 ltrs back in, I managed to get the drain plug out.
    Didn't measure mine when I drained it, but I reckon around 3ltrs came out of it.
    06 plate CDTi Signum.
    Mick
    Regular Member Jezzy's Avatar
    S.E
    Put 2.2 litres back in, in case some is still left in there. Even if it's all out, having just 2.2 in there is fine.
  1. just for clarification tid to gid
    By Sharks35 in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2012, 21:06
  2. Need clarification?? BIB ????
    By mc_orion in forum General Chat
    Last Post: 11th September 2011, 18:55
  3. Clarification Required - 2.2 Direct Fuel Pump!!
    By Calamity Gian in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 10:22
  4. Information required re automatic gearbox
    By m0cea in forum Engine & Drivetrain
    Last Post: 18th January 2009, 22:19
  5. Automatic gearbox oil and cooler info required.
    Last Post: 21st September 2008, 00:05
new dranplug f40 gearbox
