Page 1 of 9 123 ... LastLast
Results 1 to 10 of 84
Thread: Vectra C 2.0 dti decat
    Jun 2011
    London
    Talking Vectra C 2.0 dti decat
    Just DIYed mine.....very easy to do if u r ok getting durty.Took me about 3hr.Loved the result:smoother ride,better sound,no smoke.That is how i did it:lift the car safly(i just used two bottle jackes and stands for safety),take small grinder with thin blade(i have used a battery powerd makita with stainless steel blade) and cut a little door out (the size of on iphone)...CUT ONLY 3 sides of an opening cos u will bend the pease back up.now dend out thr peace that u have cut,using a drill or a whole cutter loosen up the stuff inside the cat,use a chissel or a big screw driver to chip bits out... It is harder in the begining but when u get about 25% chipped out the rest falls out in bigger pieces.when u took out all the stuff out start the car up and let all the small bits to blow out throw that opening that u have cut....bend the "door" back up ,send down aroun the cut,put some high temp sealant around,cut out a piece of any galvanized or zinc plated tin(i have used a pieace of ducting)DO NOT forget to cut the tin 20mm bigger than the cut u made!!!using self tapping screws fix the patch.Start up the car and let it idle untill it heats up the "decat" so sealant can harden.Next step is very importante!!!!!!!lower the car,wash up and go for a spin.....u will love it
    Jun 2011
    London
    NB!!!!!!very importante!!!!use a dust mask and safety gasses please!!!!!!
    Jun 2011
    Herts
    where in london are you based?? would love to hear and feel the difference as am considering doing mine :-)
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    still havent got round to doing mine but as evry one says nothing but good things after think im going to have to find the time. would it not have been easier to just remove it and bash the guts out with a bar, sure thats how others have done it.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    The DTi's really do benefit from a decat. It'll take a fair few miles for the ECUs to learn the changes so they should get a little better yet. Next, get the middle box out!
    Jun 2011
    London
    Quote Originally Posted by dansri View Post
    The problem is that vectra c dti cat is one piece pipe from turbo to middle piece and there is no way to take cat out to bash it out!
    Jun 2011
    London
    Talking
    Quote Originally Posted by cont1204 View Post
    U r 100% correct i feel more changes in performance every day,not a lot but feels good
    Jun 2011
    London
    Quote Originally Posted by FLOB View Post
    Wood green!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Pulja View Post
    Pipe off, long bar, smash the guts out. At least it saves cutting holes in the exhaust
    Jun 2011
    Herts
    Wood green!
    send me a pm with your number if you don't mind me popping to see and hear the results- I'm from that area origionally and visit my mum at weekends so could stop by :-D
  1. vectra c sri 2.2 dti decat
    By garyvectrac in forum Diesel Engine related
    Last Post: 28th February 2013, 18:19
  2. Where can i get a Decat pipe from for my Vectra C Diesel??
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 16th July 2012, 22:19
  3. vectra 2.0 dti decat
    By corbo152 in forum East Midlands (RO - dog_poop - ARO - newboy)
    Last Post: 3rd November 2011, 21:05
  4. Removing decat off vectra
    By Gt-Coupe in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 00:05
  5. Vectra VXR Decat & Silencer Removed
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2009, 17:52
vectra c 2.0 dti decat
Vectra dti downpipe removal
vectra c 2.0 dti decat pipe
vauxhall vectra c 2.0 dti decat
vectra dti decat
vauxhall zafira 2.0dti decat
zafira dti decat
