Thread: Vectra C Steering Wheel
    Jun 2011
    Helensburgh
    Default Vectra C Steering Wheel
    I have recently bought a 2004(54 Plate) pre facelift 1.9CDTi Elite. I would like to change the 4 spoke steering wheel for the 3 spoke version from a facelift model. Is this a straight swap ie are the splines on the steering column shaft the same, & can you also use the 3 spoke wheel from an Astra H (Mk5). All advice greatly appreciated.
    Many Thanks
    Regular Member Jezzy's Avatar
    S.E
    I'm not 100% sure, but I think the Astra wheel will be full CANbus, whereas your car may be full CANbus or it maybe half CANbus. The two aren't compatible, so yours would need to be full for the swap to be plug and play.
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    I've made a swap in mine but it's facelift and the wheel was taken from Zafira OPC. Only problem was the radio steering controls plug which didnt fit and needed to be replaced with mine.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Happiepostie put one from an Astra on his vec, sure he said it needed a slight modification to fit though.
  1. Will this fit A Vectra C Sri Steering Wheel???
    By tallica371 in forum Bodywork & Interior
    Last Post: 19th May 2007, 12:29
  2. '06 steering wheel into '02 Vectra
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2007, 18:14
https:www.vectra-c.comforumshowthread.php140699-Vectra-C-Steering-Wheel
vectra c facelift steering wheel fit pre facelift www.vectra-c.com
vectra wheel fit astra h steeri g
