Thread: How to
    Jun 2011
    London
    confused How to
    Hello,does anyone know what is a stock boost on vectra c 2.0 dti?can it be increased,is it safe .......is it worth it?thank you.
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Fit a boost gauge, then you will know what your's is running. You can increase the boost at bottom end quite safely but at top end it might over speed the turbo and cause damage. 20% more boost upto 3000rpm should be fine as You would need to move 60% more air at 5000rpm than 3000rpm to give the same pressure, so running just 20% more pressure upto 3000rpm should be well under the turbos max working rpm.
    Jun 2011
    London
    Thank you for replying,do i increese the boost manualy or do i have to remap?
    Jun 2011
    London
    NB,i heard that it is possable to edjust a push rod on the waste gate do you know anything about that?
    Jun 2011
    London
    just got my new boost guage esterday........i im going to install it ,nice day
    Jun 2011
    London
    just done it!!!! It is 1.4 psi at 3000 rpm,srcond gear
