Thread: Where is fuel filter on 3.0 V6 cdti
    Aug 2009
    Ascot
    Default Where is fuel filter on 3.0 V6 cdti
    Where is fuel filter on 3.0 V6 cdti?
    Nick
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Being a british version it will be on the right of the header tank, it's black.
    Aug 2009
    Ascot
    Quote Originally Posted by Celes View Post
    Is it a simple job? May do today as I have the day off
    Nick
    yeah fairly simple
    one torx screw on the top undo it
    gently lift the top of the housing out of the way it can be a bit fiddly but it is possible
    remove old filter
    put in new one
    fill with clean diesel
    replace housing o ring that sits in the groove
    screw top back on
    job done
    Regular Member bigdave1701's Avatar
    York
    If its anything like the fuel filter on the DTi, It's technically easy (couple of bolts and a clip or two) but s**t scary if you let air into the fuel lines as the car wont start afterwards.
    Not sure if the cdti engine suffers the same issue though
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Quote Originally Posted by bigdave1701 View Post
    I have a suspicion that it self bleeds as i've just done mine and it seemed to start too easy after air got in! Failing that do it at the top of a hill and bump it down to pull the fuel through maybe?
    Quote Originally Posted by BigWilko View Post
    just fill it with diesel till most of the filter is covered
    it may start and stall a couple of times while cranking it but it will bleed itself in the end and then roberts your mothers brother
    As above - fill it up and when you start it and it catches give it some beans for ten seconds or so so that any air in the lines doesn't stall the engine...
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Penfold101 View Post
    I did this but it still stalled. About 15 turns and it fired up though
    some times it does take longer , its just one of those things
    ive had it go first time
    and other times cranking for about 2 mins before it fired
  1. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  2. fuel filter 1.9 CDTi
    By chrisgettings in forum Diesel Engine related
    Last Post: 30th January 2012, 14:33
  3. fuel filter cdti 150 .
    By dave r in forum Engine & Drivetrain
    Last Post: 14th April 2010, 20:22
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. Cdti Fuel Filter
    Last Post: 11th June 2008, 22:14
