Results 1 to 10 of 19
Thread: photoshop help..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default photoshop help..
    I need a bit of help with joining 2 pictures.. (i cant do it my self..)
    But have this very long thread.. for retrofit power tailgate.. http://www.vectra-c.com/forum/showthread.php?t=121114
    now we are finaly at the last stage..
    we need to figure out excatly where to drill a hole and fit a pivot joint ... but we only have the pictures.. sooo... task is..
    Make sure things in picture are the same "size" compared to each other.. and then put together in 1 picture, so its shown where the new joint should be....
    We have this pictures..
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Rather AutoCAD than Photoshop mate. I work with this program everyday so just decided to make some quick scaling and measurement for you. Hope I got right what you mean. All dimensions in milimeters. Let me know if it's enough to make this opening.
    Engine : 2.2 Direct
    I think you got it a bit right.. (i know Auto Cad by name thats all.. even more complicated for me..)
    i know the problem is different angels on the pictures..
    And as i read the lines.. from the center of the old Pivot, it should be move 25,11 MM towards the rear screen.
    But on the lower picture it looks like the joint should be 18 mm from rear screen..
    that is if the soldering joints are at the same spot.
    (should i try to get som better pitures more centred.. so you can see the joint better from the side?)
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    do you have to change that bracket to one like on the blue car??
    Engine : 2.2 Direct
    We dont think so... not sure yet.. but ive got new pivot joints home, but need to be completly sure on where to put them.. as there also have to be room on the bracket for the strut when tailgate is closed..
    So hopefully only need to change the pivot.. and not have to make a complet new bracket... (or tailgate....)
    Engine : 2.2 Direct
    Got some new pictures today.. still not perfect.. but the pivot ball is 10mm i diameter.. (trying to get the pictures out of the iphone)
    Engine : 2.2 Direct
    heres 2 new pictures.. (on purpose that i only link to them.. as they are quite large..)
    http://danborg.org/vectra-c/pivot.jpg
    http://danborg.org/vectra-c/pivot1.jpg
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    Pictures:
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Engine : 2.2 Direct
    GTS -> have you had time to play?
    Oct 2010
    Poland
    Quote Originally Posted by kenp View Post
    Hey mate, yep, just came back from airport so if I don't do it today, then tomorrow afternoon for sure.
  1. Photoshop Please :)
    By OllyT in forum Photoshop section
    Last Post: 23rd August 2011, 23:39
  2. Can anyone do me a wee photoshop
    By Graeme in forum Photoshop section
    Last Post: 1st April 2011, 18:56
  3. Photoshop
    By craig-k in forum Photoshop section
    Last Post: 6th February 2009, 19:05
  4. can someone photoshop for me please
    By jb-redbull in forum Photoshop section
    Last Post: 4th February 2009, 18:21
  5. Photoshop help...
    By Harry in forum Photoshop section
    Last Post: 21st June 2008, 19:32
