Results 1 to 10 of 20
Thread: Changing the remote frequency ?
    Kingston Upon Hull
    Default Changing the remote frequency ?
    Hi all some times at work after parking my car i come out after work and it is open i am presuming there is another car using the same frequency on there remote
    Is there a way of changing the Frequency
    Thankyou Jacko
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    u sure u locking it silly but i do it too unlock it when i mean to lock it
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    its easy to do, ive started checking the door before i walk away because ive done it too often!
    Sep 2010
    in a box
    Quote Originally Posted by michael_linford View Post
    im not the only one then
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    lol, i dont feel so daft now!
    Kingston Upon Hull
    Yes i defiantly lock it i use the lock in the door handle i have been doing it this way for a few weeks now just to be on the safe side
    Kingston Upon Hull
    Bump Can anyone help with info please
    Jacko
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    All remotes run 433 mhz i think. the remote is assigned to the car anyway. No 2 cars are the same..
    If the battery on the handset is flat, it can result in the central locking reopening the car
    However the car is designed to relock itself if the key is not within range after a specific time
    I have tested this before, just to make sure
    Sounds to me like the key is remaining within range, hence leaving the car open and unlocked
    If you are locking the car manually, then remove the battery
    The alarm will sound on unlocking the car, and is then cancelled on inserting the key into the ignition
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Mine relocks itself if the drivers door isnt opened within a certain time, I can be stood right next to the car talking to someone and it locks, it has nothing to do with the range, what if you park in your garage and your keys are hung on the kitchen wall joining the garage?
    Also if the fob battery dies all it does is stop the remote working, no way should it pop the locks, I think you need your fob looking at if that's the case m8inter..... You can then unlock the car manually and turn of the alarm by inserting the key in the ignition.
  1. Changing old remote key for new one. Help please
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 18:37
  2. Overheard on a UHF frequency,,,,
    By Derek Mc in forum Comedy & Humour
    Last Post: 12th September 2010, 20:24
  3. ear popping vibration/frequency on 1.9 veccy sri??
    By marky2027 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th June 2009, 20:33
  4. Frequency of timing belt/chain
    By CNC in forum Engine & Drivetrain
    Last Post: 3rd October 2008, 21:00
  5. AM frequency
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2008, 22:16
https:www.vectra-c.comforumshowthread.php140649-Changing-the-remote-frequency
