Results 1 to 10 of 20
Thread: Those who understand the 3.0 V6 cdti
    Aug 2009
    Ascot
    Default Those who understand the 3.0 V6 cdti
    Hi,
    Well I have now got the eml working by taking dash apart and cleaning plug e.t.c
    But again car coughed and spluttered tonight and went into limp mode but NO eml or spanner light !?!?!
    Surely if it's scv's eml or spanner light should come on?
    Nick
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it defiantly getting enough fuel?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Only sometimes cause if the engine plays up and it sure why it gets a light. Safest bet is to get it tested properly
    Quote Originally Posted by s2yob View Post
    No, not unless it has had the EMS update or the fuel input falls below 40%
    The issue with a blocked SCV is the other remains fully working
    This is also why it took the VX dealership I use some time to work out what is wrong with it, as they rely too heavily on fault codes instead of mechanical diagnostics (nearly 3 months)
    How is the engine on idle?
    I would suggest phoning some local garages and ask if they know of a diesel specialist familiar with the the Y30DT
    It took me a while to find one
    Aug 2009
    Ascot
    I had code read yesterday and it was P0063 - No fault found. Although looking that code is for " fuel system leak - large "
    As a question mine is a facelift 06 - is that still a Y30DT?
    Nick
    Need to do a diagnosis by stage
    As above, how is the engine on idle?
    I had code read yesterday and it was P0063 - No fault found. Although looking that code is for fuel system leak - large
    This would suggest a blocked SCV or fuel pump issue
    No, this is a Z30DT
    The Z30DT is supposed to have the uprated SCV and the updated EMS
    However, as above it will only put the engine into safe mode and return the engine warning light when the issue is extremely bad
    Aug 2009
    Ascot
    Idle car is fine, no issue.
    It only happens under load
    Nick
    That confirms one of the two SCV is blocked
    As above, start phoning around to find a mechanic familiar with the Z30DT and replacing the SCVs
    If they ask what a SCV is, hang up
    Equally, you seem to be the first person affected by this on the Z30DT
    I would report this to Vauxhall
    So therefore, what mileage and service history?
    Do you have a third party warranty?
    Where did you obtain the car from?
    Aug 2009
    Ascot
    Being the first one with Z30DT is just about my luck at mo.
    Would I not be better getting work done at vauxhall?
    Car is 107,000 miles with ( supposed ) full service history from drive vauxhall.
    Car was purchased 15 days ago from dealer in hounslow ( who I have contacted and said they need to sort it )
    A quick question none related, it says on logbook that colour is grey but paint code is for mystic morning green ( a weird blue/green/grey ) would this be a keying error at registration as everything else checked out with car including finance company
    Nick
    Is this dealer independent or VX?
    Car needs to be fit for purpose
    However on this mileage your limit will be 30 days
    I would take it back NOW and discuss with them
    Perhaps you could negotiate that they take it to a VX dealership for diagnosis and repair
    You could take it to a VX dealership before doing so (a different one that they are likely to use), probably cost you £80 in diagnostic fees
    Ask for a written report and quote on completion
    Now the bad news
    A typical SCV replacement (entire job) costs near on £1000
    However once completed it resolves the issue
    As I mentioned earlier, I would escalate this to VX as the Z30DT is not supposed to suffer this as it has the uprated SCV from new
    From that we move on to the service history
    Is it entirely VX or just any VAT registered garage?
    From the stamps could you trace these garages?
    Finally, who was the previous owner and did you contact them to find out why they disposed of it?
    The V5 simply states the main colour, so this will be the agreed colour for the manufacturers colour
    You will find the paint code on the B pillar on the drivers door
    Post the code and we will give you what VX call it
  1. Anyone understand tax codes?
    By bigdave1701 in forum General Chat
    Last Post: 28th June 2012, 11:24
  2. now I understand
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 16:07
  3. Dont Understand.....
    By spoons in forum General Chat
    Last Post: 23rd August 2008, 14:25
  4. Do you understand computers????
    By ROY2593 in forum General Chat
    Last Post: 2nd July 2007, 12:34
  5. I Cant Understand It
    By VauxVeteran in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2006, 02:15
