Results 1 to 3 of 3
Thread: Aux Belt Tensioner and guide/pully
    May 2008
    manchester
    Default Aux Belt Tensioner and guide/pully
    Hi All
    I need a new belt tensioner and a pully/guide for my 1.9 cdti 120.
    Anyone any idea how much roughly a local garage should be charging for this?
    Or is it an easy job myself? Think i can release the belt ok,but is the small guide pully and the tensioner itself easy to come off?
    Also I had a new timing belt on 70k and am coming to 140k now,is it advisable to replace the water pump too this time.
    Mike
    i did the aux belt and tensioner on my v6 cdti on monday
    took about 25 mins all in
    tensioner is only held on with 2 6mm allen key bolts
    hardest part was getting the belt fed properly and located
    and yes if changing timing belt on the 1.9 do the water pump as well
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    2003 Vauxhall Vectra GSi 3.2 V6
  1. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  2. tensioner pully no good?
    Last Post: 3rd May 2011, 19:18
  3. Crank Shaft tensioner pully just went
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th January 2011, 08:55
