Thread: clutch
    exeter
    Default clutch
    just had a new clutch done 2 months ago now my clutch is sliping again( 2000 miles) . took it back to the garage and was told it was because of my flywheel was worn low . so now i got to get a new clutch and flywheel fitted ? not happy
    West
    unfortunately when doing the clutch you should always do the dmf at the same time
    london
    garage should of advised as said above- everything I've read says change both clutch and flywheel if one of them goes and change the concentric slave cylinder too. sometimes saving money short term ends up costing more than you can imagine. did they not advise the complete kit chsnge first time round?? was it the same garage?? if so they'd have known you'd be back...........
    Regular Member suresh.chohan's Avatar
    Feb 2011
    Leeds
    Vehicle : Insignia
    Engine : 2.0 CDTI
    Is this covered by the Vaux Warranty if the car is under 3 years old? The reason i am asking is, that i think mine is slipping as well:-(
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My missus learnt the hard way. Changed the rattly DMF, and 800 miles later, the clutch plate literally shattered when she was driving!
    exeter
    Quote Originally Posted by delberto View Post
    no he didnt say anything about it and he even done the concentric slave cylinder . all he said is it was low but ok . now a1 clutches has told me they both will need doing again . which it should have the frist time
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    cant see ehy you will ned a new clutch tho
    Nov 2007
    Doncaster
    MY clutch is slipping and I have entered the land of the DM flywheel,I can't get this if I want a clutch plate renewing Why does the flywheel as well cos your talking big money as soon as you talk Vectra clutch,, out the woodwork come the flywheel virus al with £ signs flashing I don't gerritt .
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
